New Audio System, Rattles all over! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-02-2013, 01:59 PM Thread Starter
TX_TRU_STUD's Avatar
Quoted: 41 Post(s)
I just got a new sound system and it sounds pretty good. My issue is that the rattles are all over the place.
I have rattles in...
1. The rear view mirror
2. Entire back wall
3. Sliding window
4. Front door speaker mounts
My concern is that I wont be able to get rid of them. Any ideas?
I know I can use Dynamat on the door speakers and back walls, but the back window and the rear view mirror are going to be tougher. Can I place a small amount of Dynamat on the back of the mirror and see if that helps? I am asking before I buy it and want to get ideas. It is like the outside plastic shell is not tight enough and when I hold the mirror, it doesn't rattle.
The rear window I have no idea how to fix.
TX_TRU_STUD is offline
post #2 of 11 Old 07-02-2013, 06:26 PM
turn the bass down or deal with it
Truckless
Garett742 is offline
post #3 of 11 Old 07-02-2013, 06:38 PM
I installed second skin products all over my truck with great success. Used their luxury liner pro and dampener pro pretty much everywhere except the floor and headliner. The rattles are pretty much non existent. And I'm sure I have more bass than you do so yeah it's possible.
cc2cuz is offline
post #4 of 11 Old 07-02-2013, 10:29 PM
Quoted: 7 Post(s)
Coming from a long history in professional car audio, I offer you this advice. Dynamat is a great product, however, it WILL NOT get rid of rattles. They are caused by two objects vibrating together. You will need to start tightening loose screws, panels, etc. You can also start putting weatherstriping type foam in areas where there are rattles. You want to keep hard surfaces which hit each other, away from each other. A good example of this is plastic door panels which are held on with a moulded hook. Cover the hook (inside part) with foam so the plastic is not in contact with the metal of the door. If you can't keep them from touching, you want to keep tension between them to keep them together so they become one.
Hope this helps (and makes sense)
Shim is offline
post #5 of 11 Old 07-03-2013, 10:12 AM
Rearview mirror rattles I cant fix, The sliding rear window I folded up a shirt and slid behind the headrest in the center cant see it cause the window tint is dark. The rear wall still rattles but I stopped alot of it by removing the air vents. I have two twelves behind the seat with a punch power 1500 so its pretty loud. The most annoying one is the rearview mirror.
Hardtopz28 is offline
post #6 of 11 Old 07-04-2013, 07:33 AM Thread Starter
Quoted: 41 Post(s)
Thanks for all the ideas guys, keep them coming
post #7 of 11 Old 07-04-2013, 03:07 PM
scummins's Avatar
Try and turn the bass frequency down. The mid to high bass creates annoying vibrations. I think mine is around 20 hz on my jl 500/1 and it really cut down the rear view mirror rattling, and sounds awesome.
11 Lariat
6" lift, 37's, Moto Metals, H&S, SPE, JL SPL2K
scummins is offline
post #8 of 11 Old 07-06-2013, 03:44 PM
hdodt's Avatar
Maybe try these on the mirror... http://www.yeoldearcheryshoppe.com/s...FRRk7Aod9VwACA
2006 F350 Lariat
EL CAT1 coolant and coolant filter.
95k miles. Oil cooler changed at 93k.
Oversized turbo oil drain tube.
hdodt is offline
post #9 of 11 Old 07-06-2013, 04:27 PM
ucpa111's Avatar
Quoted: 2 Post(s)
Just think what it's doing to your ears! When you're 50 you'll wish you didn't turn it up....cause you'll be sporting some nice hearing aids....but...someone has to buy them. LOL.
Good luck with the rattles. I used foam tape on my one tundra to deal with an annoying dash rattle that was there when cold outside.
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #10 of 11 Old 07-06-2013, 05:52 PM
I installed a 700 Watt 6 speaker stereo system in my truck. No rattles. Great sound is not = hearing damage. Loud sound is.
JohnDS is offline
