strange sounds after shut down - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-26-2013, 09:12 AM Thread Starter
insuranceman's Avatar
My truck recently started making weird sounds after I shut my truck off. I found a you tube clip of a different truck making the same sounds. I later found the clip was posted on this forum in another section but I am not getting much response. Is this sound normal? Are a lot of your guys trucks making this noise?
Heres the clip link
h5NW91Km_tq8Tbbiv-7-i-FMOdeEKrI=[/URL].
2015 Platinum
Stock for now.....
insuranceman is offline
post #2 of 6 Old 06-26-2013, 09:13 AM Thread Starter
It does not start making the noise until about 20 seconds into the clip.
2015 Platinum
Stock for now.....
post #3 of 6 Old 06-26-2013, 09:23 AM
Hawkeye Diesel's Avatar
Mine makes that noise as well, usually a few minutes after I shut the engine down. To the best of my knowledge, and I may be wrong, but I believe that is the EGR valve, or something to do with the EGR
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #4 of 6 Old 06-26-2013, 09:26 AM
dieselflash's Avatar
Thats the vacuum bleeding off at the wastegate actuator, its a common problem,Ford says its normal and not to repair,but lots of tech are replacing the actuator because of it.
Ford Master Diesel Tech
dieselflash is offline
post #5 of 6 Old 07-01-2013, 12:34 PM
Noise
My 11' does same thing, my wife says it's possessed. Sounds like it's growling
southernman13 is offline
post #6 of 6 Old 07-01-2013, 07:25 PM
raftdaddy's Avatar
my 12 has been doing that since day one.thought that was normal. def system has a circulation too?? mine is the most noticeable mid truck.
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
