2013 Stock with deletes EGT - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 18 Old 06-23-2013, 05:52 AM Thread Starter
2013F250Tank's Avatar
My 250 with 4" DP back exhaust and egr cooler block plates hit 936* in stock mod. Anyone else getting this high?
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #2 of 18 Old 06-23-2013, 12:10 PM
BIG Laing's Avatar
Is that pre turbo?
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #3 of 18 Old 06-23-2013, 02:42 PM Thread Starter
of course.
2012 F250 TOTALED.
post #4 of 18 Old 06-23-2013, 03:05 PM
BIG Laing's Avatar
Then it's nothing to worry about.
post #5 of 18 Old 06-23-2013, 03:38 PM Thread Starter
not what i asked....
2012 F250 TOTALED.
post #6 of 18 Old 06-23-2013, 03:52 PM
I seen a little higher than that with an all stock truck, obviously the egt was post turbo but it cracked 1000. You worried about it or something?
jordan572 is offline
post #7 of 18 Old 06-23-2013, 04:06 PM
05_PSD_Erik's Avatar
Please clarify your question. Was this sitting still and idling? Was this driving? What speed, how much throttle, did you have a load or trailer hooked up?
Post turbo EGT readings aren't doing you very much good. You need to watch the EGTs pre-turbo. The whole reason we monitor EGT is to make sure we aren;t 'cooking' the turbo with crazy high EGTs
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #8 of 18 Old 06-23-2013, 04:14 PM Thread Starter
obviously not sitting still or idling.......... Just hod roding around town with no extra weight. I know what temps are bad. Asking if anyone else out there has seen these temps with stock hp setting but DPF delete. My 12 never went over 750 in stock mod.
2012 F250 TOTALED.
post #9 of 18 Old 06-23-2013, 04:21 PM
Depending on what tuner you are using, "stock" settings actually do add a little bit of horsepower, usually around 45-55 or so. This gain (from the best I can tell, this is by no means a hard answer with numbers to back it up) is from the truck using a stock fuel map but it no longer has the added resistance of the DPF to flow through at all times, the DPF is a huge piece of resistance in the exhaust stream. That, and every truck responds to tuning differently, you put the same setup on another 2013 and you will most likely see somewhat different numbers.
Type RS BOV
CAI
Muffler Delete
post #10 of 18 Old 06-23-2013, 04:28 PM Thread Starter
Wow that is the most beat around the bush answer with not answering my question but thanks for your time. lol
2012 F250 TOTALED.
