2013 F250 steering - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-22-2013, 06:43 AM Thread Starter
meuth0001's Avatar
2013 F250 steering
I have a 2013 F250, I added the 6" 4link kit BDS KIT. All the upgrades and fox resi shocks! Wondering why the steering is so loose feeling? And is there any upgrades I can do?
I have the fox dual steering stabilizers too
meuth0001 is offline
post #2 of 15 Old 06-24-2013, 05:47 PM
OneTon2011's Avatar
Quoted: 6 Post(s)
I have a 2011 f350 n started out with a 4"4-link n was the same way. I have since gone to 8.5" 4-link n still the same. I can't see how it could b steering box. I have a couple days off n ima try n look through front end n see if I can find y steering is loose.
Shawn - 2011 Super Duty 6.7L Lariat
Oxford White / Sterling Grey two tone
SUSPENSION UNDER CONSTRUCTION!!!!
SS M-16 40x14.50r22 / 22x12 Gear Alloy BIG BLOCK
YUKON 4:30 / MONSTER HOOKS
AMP RESEARCH / RIGID / RECON
PMF / BUSHWACKER / AFE CAI
H&S MINI MAXX / H&S DELETE / ARE
FLO-PRO / PLAIN N SIMPLE / ROAD ARMOR
OneTon2011 is offline
post #3 of 15 Old 06-24-2013, 06:47 PM
My guess would be that the engineers never intended for 37-38" tires to be put under it. Probably not much your going to be able to do about the loose steering short of taking the lift off. Just my 2 cents, truck looks way good though!
2011 f-250, lariat with nav. 20' dale jr. Racing rims with Mickey Thompson 33" tires. Painted to match grill coming soon. Stock exhaust, waiting for warranty to expire.
nikky_dean is offline
post #4 of 15 Old 06-25-2013, 05:06 AM
I think that the alignment shops don't take into account the road force incurred by these bigger tires they aren't putting enough tow into it when they set the truck up. I've had this conversation with several of those who should know in the industry.
The recommendation at this point is to increase the amount of tow in to .25° to .3°, right now I'm at .18° and on the highway it just feels like it hunts all the time.
I'm told no more than .3° or you could induce death wobble.
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #5 of 15 Old 06-25-2013, 11:40 AM Thread Starter
meuth0001's Avatar
Thanks for the replies! I hope I can figure something out! It's not getting any better. Would love to have half as good of steering as my 11 dmax
post #6 of 15 Old 06-25-2013, 12:44 PM
Did you torque the nut on the pitman arm to the right lbs? You can look at the arm and see if it made it to the old make on the splines. Mine was doing the same thing till I bought a wrench and used my legs and pushed off the diff to get it sucked all the way in. After that no more play or walking from the steering or the wheels.
2011 King Ranch, Spartan WarHammer, AFE 4" full exhaust, AFE CAI, 8" Pro Comp lift, 24x12 American Force shield SS8 wheels on 38x13.5 Nitto trailgrapplers, Spyder CCFL lights, LED tails lights and 3rd brake light. Kicker comp 10" low profile subs w/memphis 1000 amp.
Superduty6.7 is offline
post #7 of 15 Old 06-25-2013, 04:43 PM
OneTon2011's Avatar
Quoted: 6 Post(s)
Went n bought a 1 7/8" wrench n tightened the nut on the pitman arm. No more steering issues. All is good n man was that loose. Def will keep my eyes on it. I even tightened up the nut that holds the tire rod to the pitman arm.
post #8 of 15 Old 06-25-2013, 05:00 PM Thread Starter
meuth0001's Avatar
How tight did you tighten it? I tightened mine up some today but didn't know when to stop. I was used break bar and cheater bar.
post #9 of 15 Old 06-25-2013, 05:03 PM
OneTon2011's Avatar
Quoted: 6 Post(s)
I tightened till I didn't have anything left in the arms n legs lol n used some loc-tight.
post #10 of 15 Old 06-25-2013, 05:20 PM
Believe me if the ratchet with cheater bar is flexing your not getting all the lbs that it needs. You need to buy a wrench with open end and closed, I got one on ebay for $27 its about 24 inches long and you don't have to remove any of the brackets to get the wrench in. You put the wrench on and push off the diff with your legs if you don't have the *** behind it to get it all the way in you can tie the wrench down and use power steering to rotate the nut while the wrench is stationary to tighten itself.
