Motorcraft 15w-40 - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 13 Old 06-11-2013, 04:17 PM Thread Starter
Motorcraft 15w-40
Anyone using this stuff in their 6.7? I used it all the time in my 6.4 with no issues. The dealer is telling me 10w-30 and the cap says 5w-40 for severe duty. I am middle of the road as far as duty is concerned, and I live in SC so the climate is warm. I get the best price on Motorcraft 15w-40 but want to know if there is an absolute reason not to use it in a 6.7.
Fordcrazy is offline
post #2 of 13 Old 06-11-2013, 07:12 PM
First oil change on my 6.7 was performed by the dealer today and they used 15/40. Not sure why - there was an info note on the invoice indicating "Days / Hours". Guess maybe that caused it to slip into the severe usage category.
2013 F-250 Lariat
JSolve is offline
post #3 of 13 Old 06-12-2013, 03:04 AM
Had 5-40 full synthetic put in mine while living in Vegas. No issues
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #4 of 13 Old 06-12-2013, 04:42 AM
75000 miles very light knock. Stock everything deleted and tuner from day one.
Notice nothing went through these and only the top bearings are fatigued and worn. We clearanced the engine on a rebuild and found all oil clearances within spec on the very tight side. Spec is .001-.003 and they were right at .001. We polished the crank to a looser clearance and will be running 15-40 shell rotella.
What are everyone's thoughts on a .001-.0015 oil clearance in a diesel truck and is the 5w-40 oil going to have a thick enough film at higher torque levels?
note this is a fleet vehicle that is towed with on a hot tune day after day.
also note the bearings are black coated upper, and normal babbit lower.
cfd_shop is offline
post #5 of 13 Old 06-12-2013, 05:14 AM
Is the bearing still smooth?
jcain is offline
post #6 of 13 Old 06-12-2013, 05:32 AM
Without touching or seeing the bearing first hand, it looks like an abused vehicle, cold starts straight to heavy work, and over extended oci's. Any info on the life of this engine? Oil analysis? Oci's? Fleet vehicle? weather of usage? Brand, type and weight of oil?
jcain is offline
post #7 of 13 Old 06-12-2013, 05:40 AM
I am certain they are running a 15w40 rotella oil in it.
The main bearings were perfect as well as the crankshaft.
Cylinder alls still have a great crosshatch.
It is a fleet vehicle and is worked hard on a hot tune day after day by multiple drivers.
The bearings themselves are smooth.
cfd_shop is offline
post #8 of 13 Old 06-12-2013, 05:42 AM
MAHLE Clevite - Bearing Analysis - BETA v3
here is guide for everyone to study bearing failure
I am kinda partial to #4 excessive crush at this point by the appearance.
note #16 wiped would be an earlier sign of oil starvation and I do not see any metal being wiped across the bearing
cfd_shop is offline
post #9 of 13 Old 06-12-2013, 05:55 AM
Really need an oil analysis to point a sure finger. Excessive idling (fleet truck) would prematurely break the oil down and render it useless when the truck got flogged to the next job.
jcain is offline
post #10 of 13 Old 06-12-2013, 06:21 AM
We do not do the maintenance so I am unsure of the oil change interval.
cfd_shop is offline
