Tire rotation - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-11-2013, 12:11 PM Thread Starter
Ish
Ish's Avatar
Tire rotation
Was just curious how often I should rotate my tires! I'm running mud tires.... I heard every 5,000 miles?!?!
Ish is offline
post #2 of 13 Old 06-11-2013, 12:27 PM
Snake's Avatar
Quoted: 46 Post(s)
That's a good number to use. Any more often and it becomes a PITA. Any less often and you increase the risk of the tires wearing unevenly.
Truckless
Bulletproof Diesel www.bulletproofdiesel.com
1-A Auto Parts www.1aauto.com
Snake is offline
post #3 of 13 Old 06-11-2013, 12:28 PM
JUGGS's Avatar
I rotate mine every other oil change (10k), and I just do front to rear (no diagonal). I don't know if I'm doing it correctly but I've been running M/T tires for about 15 years and I always get good wear out of them. Also, they stay fairly quiet and smooth.
2005 F250 Lariat CCSB/170k mi./6sp Handshaker
Don't Worry
Dieselsite coolant filter, CAT ELC, Bulletproofed and monitored by BPD
Be Happy
SCT SF3, 4" Flo Pro, 2.5" Readylift SST, 35" GoodYear Fierce Attitude M/T's
JUGGS is offline
post #4 of 13 Old 06-11-2013, 01:20 PM Thread Starter
Ish
Ish's Avatar
Thanks guys
Ish is offline
post #5 of 13 Old 06-11-2013, 01:59 PM
JUGGS's Avatar
You bet. I also use a trick my dad taught me to make sure I have the correct PSI in front and correct in rear (they aren't the same since there is less weight over the rear). Find a smooth level parking lot. Use chalk to make a 2-inch wide mark all the way across your tire tread. Drive forward (or backward) several feet, then check the chalk marks. If the chalk is only worn in the middle, take some air out. If it is worn on the outsides, add some air. You have the right pressure when the chalk wears evenly all the way across. If you do this with a new set of tires, then rotate (and adjust the front/rear air pressures accordingly) every 10k, you will have none of the complaints about mud tires that others have.
Don't Worry
Be Happy
JUGGS is offline
post #6 of 13 Old 06-11-2013, 03:02 PM Thread Starter
Ish
Ish's Avatar
Dang.... I think I'll have to try that! Good info...
Ish is offline
post #7 of 13 Old 06-11-2013, 03:58 PM
Snake's Avatar
Quoted: 46 Post(s)
Agreed. Only thing I could add is to get your tires up to temp beforehand.
Truckless
Snake is offline
post #8 of 13 Old 06-12-2013, 04:48 AM
TX_TRU_STUD's Avatar
Quoted: 41 Post(s)
So I just got a new truck and was wondering the same thing...where do I get my tires rotated if I do my own oil change? Does Ford do them on new vehicles or do you have to pay? I had tires from Discount Tire and they did them since I can remember so I have not had to deal with this before.
TX_TRU_STUD is offline
post #9 of 13 Old 06-12-2013, 05:52 AM
JUGGS's Avatar
Dad would be disappointed that I left that out.
I'm not sure, I do mine myself. Put the back axle on a couple stands and use a floor jack to lift first one side then the other up front. It only takes about 30 minutes or so and I do that while my oil drain plug is out.
Don't Worry
Be Happy
JUGGS is offline
post #10 of 13 Old 06-12-2013, 06:06 AM
Quoted: 41 Post(s)
yea I get my rotated and balanced every time...
