Tire bulging up center - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-06-2013, 03:21 PM Thread Starter
raftdaddy's Avatar
Just had it in for service and my year old bfg at 325/60/20 are raising up the center, but only in the front. It's like they all of a sudden wore out either side of the tire. Tires look good just look like a Mohawk . If you look at it from the side it's about 1/8 inch higher in the centre. The teck said this is not normal. I bought them from an online dealer but wondering I'd this is due to stock rims??
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
post #2 of 12 Old 06-06-2013, 03:53 PM
No, it's due to under inflation. When tires are over-inflated they wear out the centers first; when they're under-inflated, they wear out the edges first.
2013 F-250 Diesel 4X4 Lariat Crew Cab SRW Short Bed FX-4 with 3.31 rear
sobiloff is offline
post #3 of 12 Old 06-06-2013, 06:36 PM Thread Starter
raftdaddy's Avatar
I ran em at max psi . This almost looks like the center popped out. I had to run em at 65 or my sensors went off you can actually see it riding on the high spot with the dirt ill send pics soon
post #4 of 12 Old 06-06-2013, 06:47 PM
Randy_270's Avatar
Quoted: 2 Post(s)
My stock sized 275/70r18s wore out the centres faster than the sides on my back tires and they were inflated to 80psi which is max and recommended. I probably could have saved them if I did regular rotations but I was lazy. I bought a set of 325/65r18s to replace my stock tires but now I'm worried that if the stock ones wore in the centre then the wider ones are gonna be even worse...
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #5 of 12 Old 06-06-2013, 07:07 PM
Right, which is why you should drop your tire pressure to let the entire width of the tread make contact with the pavement.
sobiloff is offline
post #6 of 12 Old 06-06-2013, 07:15 PM
Randy_270's Avatar
Quoted: 2 Post(s)
I did but it was too late when i noticed it. After that I ran all 4 tires at 65psi.
post #7 of 12 Old 06-06-2013, 07:30 PM
Term3's Avatar
In order to get the exact amount of air needed in a tire I saw a guy take two different colors of that rubbery stuff you dip tool handles in and paint a two inch wide stripe across the tread, then after that dried he painted the second color over top the first color and let it dry. Then he would check the stripe every few miles and by seeing where the second color wore off sooner showing the first color underneath told him if he needed to add or remove air from the tires. Never tried this myself because I run stock tires but it seems to work for him.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #8 of 12 Old 06-06-2013, 07:38 PM
Yep, that's a fancy way of doing the same thing with chalk—probably with better results.
However, you should also be able to get the load-inflation chart from your tire manufacturer. A quick trip to a CAT scale will tell you the weight you have on each axle, and then you can adjust your pressures according to the load-inflation chart. (Course then you'll have to find a friendly dealer to adjust your TPMS to your new pressures, or get a tuner, to avoid the annoying "low pressure" warning at each startup.)
sobiloff is offline
post #9 of 12 Old 06-06-2013, 09:39 PM Thread Starter
raftdaddy's Avatar
i'm thinking it was the combo of over inflation and a little to narrow of rim. but the weird thing is it is not like it wore more in the center it was fairly even wear then the center raised out?the tech checked it and it is 12/32 evenly if measured in the center and 12/32 measured on the side tred.
if you look at the bfg there are 3 distinct sets of treads. the single rows on each side then a group of three wide, intertwined together. the three just raised up bout an 1/8. and now that's what i'm driving on? I had these on my 10 for 30k kms and have just recently put them on my 12 if that means anything. for 2k kms. but the rear has the same pressure and they are worn even.
post #10 of 12 Old 06-07-2013, 05:43 AM
Ah, it sounds like you're describing "feathering," which is what you see when there's too much toe in the suspension, but maybe a narrow rim could cause similar-looking issues? You might want to have a suspension shop verify the toe.
sobiloff is offline
