Replaced the power steering pump?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-04-2013, 02:31 PM Thread Starter
I replaced the power steering pump on a 12 F250. I never did it before but something is still not right and its making a strange noise. Like maybe there is air in the system? Was I supposed to make sure the air was out?? Kinda new to this. Could someone tell me step by step how its supposed to be done.
Thanks
Oh and I used power steering fluid and was reading somewhere you are supposed to use tranny fluid?
windowbarn is offline
post #2 of 4 Old 06-04-2013, 05:39 PM
topdwg's Avatar
Man not trying to sound like a smart ***, but should you have researched first how to do this? And yes you should have used tranny fluid not power steering fluid. These trucks have hydraulic assist steering that also works with the brakes...
Sent from AutoGuide.com App
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #3 of 4 Old 06-13-2015, 11:04 PM
Window barn.
Can you tell me how you removed the power steering pump as it looks like some awkward bolts to get to.Can not even see the rear ones
Any tips???
jimjan is offline
post #4 of 4 Old 06-14-2015, 06:15 AM
Quoted: 2 Post(s)
Your owner's manual should call for Mercon V ATF for the power steering, Mercon LV ATF for your transmission.
2012 F350 6.7L SRW LB CREW LARIAT ULTIMATE FX4 3.55 ELSD - SCT X4 - DELETED - 4" SS FLO PRO - NO LIMIT EGR DELETE
2012 FORD EXPEDITION EL LIMITED
2007 F350 6.0L SRW LB CREW XL FX4
2007 RANGE ROVER SUPERCHARGED
1970 FORD TORINO COBRA 429
fosterelli is offline
