CALLING ALL COOLANT EXPERTS!!! - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-21-2013, 07:38 AM Thread Starter
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
So, like the title says, I want to know exactly which coolant test kits I need to perform ALL the coolant tests for both cooling systems for my 6.7L. I have spent time researching posts and have come up with several opinions on how to do the test but I would really like somebody to step up and walk me through this, including, the correct test kits I need to buy . Like most of you, I don't feel comfortable with the stealerships telling me they tested and everything looks fine! I want to learn how to do this myself correctly and know for sure it is being done right! Thanks in advance for all the help.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #2 of 16 Old 05-21-2013, 12:20 PM
Subscribed
Id like to know too
Jason1Pa is offline
post #3 of 16 Old 05-21-2013, 04:23 PM
Dieseldawg2010's Avatar
My dealer told me that while I could test it myself and if it indicated the need for additive, I would be SOL as Ford does not allow it to be sold to te public.
I trust that dealer very much. They tested it for free every time it came on(13k miles or so) and added some around 45k.
New: 2012 F-350 Lariat CC LB 6.7L 3.55 gears w/E-Loc, Lariat Interior Package, Moonroof, FX4
Air Train Horns/4.5" Carli Starter System/Carli High Mount Stabilizer/XD Rockstar II Matte Black 18x9 5" BS/37x12.50x18 Pro Comp Xtreme AT's/2WD Chin Spoiler
Gone May 2013:
2011 F-250 KR CC SB 4x4 6.7L 3.55 gears Nav System
Gone Feb. 2011:
2004 6.0L, F350 CC 4x4, 10" Icon Lift, 4.56 gears, lockers, Moto Metal 20" wraped in 38" MT's
Dieseldawg2010 is offline
post #4 of 16 Old 05-21-2013, 04:33 PM
Hawkeye Diesel's Avatar
That is bs from your dealer, i have a bottle of the additive in my garage. They sell it in the parts department.
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #5 of 16 Old 05-21-2013, 06:27 PM
vlxjim's Avatar
Here you go. This is a post of mine on checking the coolant and what and where to buy it.
check coolant additive message
Instruction
http://www.powerstroke.org/forum/att...st-primary.pdf
2011 F250 PowerStroke CCSB Lariat FX4 Loaded | Icon 2.5" Stage 2 | Icon track bar | Top Gun Dual Stabilizers | 20" Fuel Boost wheels +1 offset | 325-60-20 Hankook Dynapro ATm | RBP RX3 steps | BakFlip F1 Bed Cover | All Sales Mfg Fuel Door | Randy Ellis Light Bar | Hella Lights | aFe Magnum FLOW Pro-GUARD 7 Air Filter |
vlxjim is offline
post #6 of 16 Old 05-21-2013, 06:52 PM
Three products are available for ensuring the life and
health of the coolant: one tool, a test kit and a coolant inhibitor additive:
• Rotunda tool ROB75240 available from your dealer – recommended
refractometer to test coolant concentration.
• Rotunda 328-00008 (Antifreeze Coolant ELC Contamination Kit) –
Evaluates the corrosion inhibitor additive strength. Note the first step
is to verify the vehicle’s coolant concentration is in the correct range
of 40 – 60%. Coolant concentrations outside this range will not
provide valid test results. If the report results in a pass (i.e., the
cooling system does not show excessive contamination/the corrosion
inhibitor additive strength is sufficient), no action is required. If the
report results as insufficient (does not pass), the corrosion inhibitor
additive strength of the coolant is too low. If the ENGINE COOLING
SYSTEM corrosion inhibitor additive strength is low, add 48 fluid oz. of
Motorcraft Specialty Orange Engine Coolant Revitalizer. If the
SECONDARY COOLING SYSTEM corrosion inhibitor additive strength
is low, add 16 fluid oz. of Motorcraft Specialty Orange Engine Coolant
Revitalizer. The coolant can be recharged with this additive up to two
times before the coolant must be changed-out. When exchanging the
full coolant volume, the system must be flushed and refilled per the
instructions in the Workshop Manual.
• Motorcraft Specialty Orange Engine Coolant Revitalizer – Additive to
boost the corrosion inhibitor level based upon the test results of the
Antifreeze Coolant ELC Contamination Kit. The revitalizer may be
added two times over the life of the coolant. If additional dosages are
required, the cooling system must be flushed and refilled per the
I don't think it is plagiarism to copy and paste from the owner's manual
JohnDS is offline
post #7 of 16 Old 05-21-2013, 06:57 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 5 Post(s)
Feedback Score: 12 reviews
Why not go with ELC coolant and not have to worry about testing and adding sca's? I run caterpillars ELC. It's 300,000 mile rated and needs a caterpillar additive at 300k interval and changed after another 200-300k miles
Sent from AutoGuide.com App
Marshall
2000 F250 7.3L CCSB 2WD
Tinted | Focal speakers & 12" Kicker | CTS Edge Insight | Wicked Wheel | 6 pos chip | 05 grill & lights | 08 mirrors & tailgate | EBVP delete | 08 console | Nathan P3 train horns & Onboard Air
Switching to hid's? Do it right!
mts678 is offline
post #8 of 16 Old 05-21-2013, 07:08 PM
Quoted: 11 Post(s)
Does the Cat ELC have the Carboxylates that coat the internal metal of the CGI block?
The main corrosion inhibitor is the Carboxylates. They slowly coat the internal metal and prevent corrosion.
On Edit, CAT ELC does contain their version of Carboxylates
CAT still recommends that you add the CAT extender at certain mileage to improve the Carboxylates and that you test for the Carboxylates periodically.
CAT says no need to add SCA since they are used with Nitrite based coolants. Which CAT's ELC and Ford Speciality Orange are not.
So what is the Advantage of using the CAT ELC vs the Ford.
Both products require periodic testing
Both products require the adding of Carboxylate boosting additive at certain mileage.
Neither product requires any SCA's, in fact the use of SCA's will require a flush and refill on the Ford system.
CAT does show 600,000 mile life vs Fords 105,000 life for the coolant. How much of that extended life if because of Larger capacity cooling systems, hiway mileage vs stop go mileage typical of pickup and other wear factors? I personally think I'd trust my Ford designed engine to use Ford Coolant.
I'm not sure I see the reason to swap out the Ford Coolant that this engine was designed around in favor of using a CAT coolant that was designed for a CAT engine.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #9 of 16 Old 05-21-2013, 07:26 PM
mts678's Avatar
Quoted: 5 Post(s)
Painted horse- frankly I'm no coolant expert, I'd have to research that and get back with you.
Marshall
mts678 is offline
post #10 of 16 Old 05-21-2013, 08:46 PM Thread Starter
Quoted: 3 Post(s)
Instruction
Thanks for the great input, this is the kind of information I was looking for.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
