2012 F250 Fuel Filter Change? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 15 Old 05-18-2013, 02:32 PM Thread Starter
Redleg's Avatar
Like the title says I have a 2012 F250 with a build date of 11/11.
Bottom fuel filter no problem but the top one PITA!
After two hours of twisting I stopped before I broke something.
Anybody have a trick to get it out? I pop off the fuel lines no problem and it's a 2012 so no bolt just twist and remove correct?
I have 15000 miles on the truck and the bottom filter was nasty and I would really like to get the top one changed but it does not want to come out.
2015 F350 Platinum CC SB 6.7 4X4
Redleg is offline
post #2 of 15 Old 05-18-2013, 04:04 PM
RTRBURN's Avatar
No there is a clamp that has a 7mm head on it.
2011 Silver F250 Lariat CCSB 4x4 6.7 H&S Deleted (mine)
2012 Burgundy F350 Lariat CCSB FX4 6.7 (wifes)
RTRBURN is offline
post #3 of 15 Old 05-18-2013, 05:22 PM Thread Starter
Redleg's Avatar
Well take a look at this one.
Like I said, no bolt that I can see.
Redleg is offline
post #4 of 15 Old 05-18-2013, 06:29 PM
My 2012 does NOT have a bolt.
I believe only the 2011's have the bolt.
Twist the filter counter-clockwise then pull straight up.
Mine was in there pretty snug so when you pull up just wiggle it back and forth while pulling. It will come up.
Hope that helps.
2012 F-350 supercab long bed srw lariat tuxedo black
MBRP 5" dp-back exhaust (thermal coated) with RBP 6" tip, AFE pro-dry s cold air intake, H&S mini maxx, H&S EGR delete, RBP rx3 nerf bars, RBP fender emblems, RBP rx2 grille with color matched grille surround, AMI color matched locking fuel lid
Soon to install..
RBP rear bumper, RBP front winch bumper w/ Warn 16.5ti, Icon 4.5" stage 3 suspension, Icon steering stabilizer/shocks, 35"x12.5" nitto trail grapplers, RBP Revolver 20" wheels
theinfamouskonrad is offline
post #5 of 15 Old 05-19-2013, 08:16 AM
dodge_dbag's Avatar
My 11 f250 company truck has a 7mm bolt and my 12 f550 doesn't as well as my personal 12 f250.
When I changed my fuel filter on the 550 I had to used a big pair of channel locks to get it loose.
08 f450 xlt fx4
11 f350 king ranch fx4
12 f250 lariat fx4
dodge_dbag is offline
post #6 of 15 Old 05-19-2013, 09:54 AM
jrshelton13's Avatar
That's weird, my 2012 has the 7mm bolt on the top filter. I just swapped mine out a week ago at 13k miles. I looked at a few YouTube videos and it was very easy. Not sure why some '12's have them and some don't, but mine sure does!
jrshelton13 is offline
post #7 of 15 Old 05-19-2013, 11:21 AM Thread Starter
Redleg's Avatar
Done!
Broke out the oil filter pliers and broke off one of the fuel line ports on the filter so no turning back now!
Wiggled it a little after turning it and it popped right out.
Next time I will start with the filter pliers and it will be a two minute job.
Redleg is offline
post #8 of 15 Old 05-19-2013, 03:56 PM
I have never had a problem changing my fuel filters, I know they are much easier than a Duramax!
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #9 of 15 Old 05-19-2013, 04:43 PM
Quoted: 12 Post(s)
Tuesday Build VS. a late afternoon Friday build.
'11 F350 6.7L FX4,
H&S Tuned & Deleted!
5" Flo-Pro
S&B Intake
Balla6.7 is offline
post #10 of 15 Old 05-19-2013, 04:51 PM
There's probably a lot of truth to that!
