dieselsite fuel/water filter experience - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 25 Old 05-17-2013, 12:16 PM Thread Starter
Has anybody installed the dieselsite fuel/water filter?? Is it really worth the $600.00 plus. This seems to be a very good way to keep the fuel clean and seperate the water. We all know what Ford does when we get water in the system. Any feed back would be appreciated. Taking a long look for my 2012 F-250 6.7.
Henry
henry is offline
post #2 of 25 Old 05-17-2013, 04:29 PM
The filters used in these are not really rated for the flow our low pressure fuel pumps put out. I've done some research on these and I'm going with a much bigger filter than the dieselsite one uses. It will be done in a couple months and I'll post pics.
2011 F350 4X4 CCSB SRW, King Ranch, 3.55, Mini Maxx, 4 inch exhaust, egr gone, Confederate Diesel turbo kit with a S363 and 0.91 twin scroll turbine housing, and stock air filter.
DirtBikePilot is offline
post #3 of 25 Old 05-18-2013, 06:18 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
x2....You can get much better filters for $50
CT Performance, Inc. is offline
post #4 of 25 Old 05-18-2013, 12:11 PM Thread Starter
Well it seems that everyone has there own opinion. What I like is the ease of installation and the filter easy access. Does any one else make the quick disconnect fittings?? maybe that would be the key to making your own version of filter, but it seems that dieselsite spent some time putting this together. How about a little more depth about the dieselsite system.
Henry
henry is offline
post #5 of 25 Old 05-18-2013, 12:20 PM
BgCountry's Avatar
Ive talked to the guys at diesel site and Im going to get one in the future. Some guys on here like it and some want to make their own. I like the set up and the ease of removing the bowls to flush out the content of the bowls. Good looking set up if you ask me.
I talked to Jim at diesel site (think thats his name) and he told me that these were made specifically for the 6.7. So, I would think that they are rated for the 6.7?
2012 F350 Lariat PS CC FX4 Tuxedo Black, Tinted, 20's, Recon Side Lens, 3rd Brake Light, De-Stickered, Epic Door Seal Mod, Reflex Liner, Spyder Headlights W/RFS 5K HID's, B&W Turn Over Ball W/Andersen Ultimate Fifth Wheel Connection.
2011 Keystone Laredo 310 RE
BgCountry is offline
post #6 of 25 Old 05-18-2013, 12:34 PM Thread Starter
Well as I said before everybody has ther opinion. But this is about the easeist install that I have ever seen on any diesel and it appears that the dual filters are as big as the stock filter. And you got to think Dieselsite did there homework before they threw this out to the public. You know that any water in the cheepo fuel pump Ford put on these trucks is going to cost you a ton of green, since Ford will not stand behind there warranty if there is any water or rust damage to the pump. I guess it depends on how much you want to spend. Its like the old Fram commercial, do you want to spend a little now or a lot later it's your choice.
Henry
henry is offline
post #7 of 25 Old 09-15-2013, 07:23 PM
Bump
any more experiences with this set up? How are they working during the cold winter months? Pros and cons? I guess I'm curious if it'll be to much wear on the fuel pump since the fuel will have to pass thru 3 filters, especially during the cold alaska winters
2012 F-250 Lariat FX4 Ultimate/Chrome Package, CC SB 3.55 ELD, Clearance Lights, Rapid Heat, Upfitters, HD Alternator, Snow Plow Prep, PTO, Husky Liners, Arma Spray-in Bed Liner, Bakflip F1 Tonneau, BFGoodrich All-Terrain T/A 325/65/R18 on Stock 18's
AK250 is offline
post #8 of 25 Old 08-01-2016, 04:49 PM
Quoted: 2 Post(s)
Anyone have an update or opinion? I am looking at installing this system on my 2012 truck which is currently at my Ford dealer with nearly $8k work of damage due to fuel contamination.
jsvaughn is offline
post #9 of 25 Old 08-01-2016, 05:00 PM
Shadowfax's Avatar
Quoted: 5 Post(s)
I had it on my last one but sold it. Now that I'm back in one I'll put another one on if I see one used. They are way overpriced I think... The setup should be $350 max even that is a stretch.
All you are paying for is ease of installation. I never found a definitive answer as to whether ford would void your warranty if they saw it either so I was always worried if break down and have to have it towed to the dealer then be screwed.
2015 f350 lariat
2003 Jetta TDI 5spd
Shadowfax is offline
The Following User Says Thank You to Shadowfax For This Useful Post:
Pro fuzz (08-03-2016)
post #10 of 25 Old 08-01-2016, 05:54 PM
heleonardman's Avatar
Quoted: 149 Post(s)
Garage
Ehhh ford don't like to see aftermarket stuff on the motor or fuel system even if it *in theory should* help filter/whatever....It's dicy...
I would agree with the filters being a bit too small on the kit and it being overpriced significantly...for the price you could get a fass or airdog lift pump with bigger filters and water seperators and be filtering AND lifting before your lift pump...double whammy
--HL
2012 F-250 6.7 CCSB XLT
Too many toys for it to list
heleonardman is offline
