2011 F250 with newly installed Carli 2.5" leveling kit - Ford Powerstroke Diesel Forum
post #1 of 24 Old 05-14-2013, 06:21 PM Thread Starter
schillster1's Avatar
So I got the new Carli 2.5" leveling kit installed on my F250 crew cab. I went with new Bilstein 5100s on all four and 4" blocks in the rear. The truck fender is 10" above the top of the front tire/tires and it's 9 1/2" above the top of the rear tires. Basically, the front of the truck is 1/2" higher. Perhaps that's level, but If I put ANY weight in the rear or tow the *** is sagging. Not cool. I can't stand pulling my boat or trailer and having people flash me at night cause the front of my truck is pointing at the sky. Worse, the truck rides really rough now! Going down the highway on the roads in Texas it shakes everything in my truck. Going down city roads at 35-40 my truck bounces all over the road. My girlfriend says it rides like my 11' F350 dually. I'm running 295/60/20 Nitto Trail Grapplers at 60 psi front, 57 psi rear. I ran them at 57,55 but they seemed to soft and ride didn't seem to improve. It's so bad I don't want to keep my truck anymore. I have new Toyo AT2 35's on Fuel Boost arriving in the next few days to replace the stock tires and Nitto Trail Grapplers. It's not a good feeling when I don't want to drive my truck anymore! Will changing out the shocks to upgraded Carli shocks or a different brand improve the ride or am I selling this rig?
HISTORY--- I've had Fords my whole life (96' F150, 99' f350, 00' F350, 05' F350, 11' F350, 11 F250). I've been a diehard Ford man. It's in our family. In 08' I switched to a GMC dually because I had heard so many bad reports on the 6.4. The truck drove great, loved the D/A combo but the truck rattled like crazy on the inside. I traded out to an 11' F350 dually and the F350 was very rough. I traded it back in on the F250. Flame me, but the GMC dually rode way better than the F350 and better than my F250.
schillster1 is offline
post #2 of 24 Old 05-15-2013, 01:56 AM
id check with ocveloman... this doesn't sound like your typical carli review!
Bopper is offline
post #3 of 24 Old 05-15-2013, 01:59 AM
BIG Laing's Avatar
This is the first time I've ever heard anything bad about Carli.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 24 Old 05-15-2013, 03:29 AM
montana6.0's Avatar
I've heard people say the 5100s do ride a bit rougher or more stiff. But when loaded feels smoother. Air bags or bigger block for squatting issues.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
montana6.0 is offline
post #5 of 24 Old 05-15-2013, 07:38 AM
OCVeloMan's Avatar
Quoted: 130 Post(s)
Garage
The measurements you're stating are correct. Note the front wheel wells are larger than the rear to give the truck the appearance that it's sitting more level than it is from the factory. As for the sagging, that's the nature of the beast... If you purchased a leveling kit, your rear wasn't addressed so it's not sagging anymore than your stock truck would; the only difference is that you're starting from level rather than the rear 1.5" taller so it appears to be sagging more.
As for the ride quality, the 5100s and linear rate springs are a nice improvement over stock as they provide more travel and control with the softer springs we provide with the system. The tire pressures are really high... I would tell you to throw on the Toyo ATII that you have in the 35" and run them at 40 psi front and 35 psi rear. That will work wonders to compliment the suspension. Upgrading to a commuter or pintop 2.5" shock will make a world of difference, yes, but I would recommend putting the tires on, lowering the pressures and seeing how you like it.
We normally tell customers to expect stock ride quality on the road with more control and travel that will be a substantial improvement in cornering and light-off-road for the leveling/starter systems. They also substantially improve large dips and rough pavement. The others that have reviewed the 2.5" leveling and starter systems have raved about them but most changed the wheel and tire combo and ran the proper tire pressures as well. The other systems improve every aspect of the daily drive.
OCVeloMan is offline
post #6 of 24 Old 05-15-2013, 06:27 PM
F350SD's Avatar
you want him to run 35psi in a rear tire on a truck that weighs close to 8000 lbs even without passengers or cargo? That's a full 30lbs under the recommended pressure for 35's on a 20" rim. The NHTSA, when conducting 'low pressure' tests, considers anything more than 8 lbs below the manufacturers recommendation to be 'low' and most studies advocate for at least 80% pressure for on-road applications. In this case - at least 50 psi.
sure, lowering the pressure will allow more sidewall flex and give the impression of a better (softer) ride but it sure isn't going to help with the cornering that you mention later in your post. It will help busted beads and tread separation though.
I could improve the comfort 'aspect of the daily drive' by not wearing my seatbelt - but that would be sacrificing safety to do it. Running those pressures in a work truck to compensate for a stiff suspension set-up is dangerous - and bad advice.
2015 F450 Platinum (me happy)
Montana 3625RE 5th wheel (wife happy)
USMC 89-93 / Wounded Warrior Project supporter
F350SD is offline
post #7 of 24 Old 05-16-2013, 12:52 AM
Subscribed!
Countypig is offline
post #8 of 24 Old 05-16-2013, 01:06 AM
BIG Laing's Avatar
Unloaded the front tires have what, 60% of the weight? maybe even 65%? (This will varry between SCLB, CCSB, CCLB, ect...)
I do agree 35 sounds crazy low... Maybe 50 front 45 rear...
post #9 of 24 Old 05-16-2013, 01:52 AM
BIG Laing's Avatar
For 35x12.5r18 the max pressure is 50, I assumed 35x12.5r20 was also 50 PSI.
So hearing 40 and 35 never seemed that odd. But after looking on toyo's website the 35x12.5r20 says 65 PSI max. So now 40 35 sounds bad.
(Sorry Dan, this ^^^ is my explanation of my last post)
post #10 of 24 Old 05-16-2013, 02:40 AM
boatpilot's Avatar
I've got the 4.5" starter on my truck with 35 toyo mt on 17" rims and I run 50 front/45 rear...Have 2500 miles on since lift and tires are wearing great and the ride is equal to if not a slight improvement over stock.
2012 F350 KR
Carli 4.5 Performance, Machined Fuel Kranks 17", 37" Toyo MT's, H&S Mini with custom tunes, H&S Cac, S&B CAI, 5" FLOPRO, EGR/DPF delete, Full replacement front and rear bumpers, toolbox, and bedrails by South Texas Outfitters, Rigid LED's, B&W hitches...and this thing is finished!
boatpilot is offline
