Check coolant light - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 19 Old 05-11-2013, 06:27 AM Thread Starter
OneTon2011's Avatar
Quoted: 4 Post(s)
Check coolant light
Ok the other day I was driving my truck home (no load on the truck) I turned right probably turned about 70% full turn at which point heard a load pop (almost like the suspension was in a bind) as soon as the pop was over my check coolant additive light came on. It's not showing up under my DTC on the mini max. I looked under truck can't see any rubbing or metal shavings, nothing! I'm lost! Any ideas?
Shawn - 2011 Super Duty 6.7L Lariat
Oxford White / Sterling Grey two tone
SKYJACKER 8.5" 4 link / 2" Spacer & add-a-leaf
SS M-16 40x14.50r22 / 22x12 Gear Alloy BIG BLOCK
YUKON 4:30 / M-95 SHOCKS / MONSTER HOOKS
AMP RESEARCH / RIGID / RECON
PMF / BUSHWACKER / AFE CAI
H&S MINI MAXX / H&S DELETE / ARE
FLO-PRO / PLAIN N SIMPLE / ROAD ARMOR
OneTon2011 is offline
post #2 of 19 Old 05-11-2013, 03:06 PM
BIG Laing's Avatar
Did you just pass 30,000 miles? Or 60?
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #3 of 19 Old 05-11-2013, 05:06 PM Thread Starter
OneTon2011's Avatar
Quoted: 4 Post(s)
neither, it has ~28K
coolant level is at the right level as well
post #4 of 19 Old 05-11-2013, 05:22 PM Thread Starter
OneTon2011's Avatar
Quoted: 4 Post(s)
I think this is a info message. I think I have to take truck into dealership and have the coolant checked with "test strips"! Anyone have any experience with this?
post #5 of 19 Old 05-11-2013, 05:50 PM
You can reset it in the dash console. Mine has came on once before. I dont think its anything to worry about.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #6 of 19 Old 05-11-2013, 06:24 PM
My light came on at 13,000 miles. I took it to the dealership and they checked it and said everything was fine and just reset it. I am deleted and also pull heavy.
You can reset it but I would let them reset it incase something happens down the road. Now I have documentation from them saying they checked it.
Just my 2 cents.
Countypig is offline
post #7 of 19 Old 05-12-2013, 06:30 PM
cumminchevy's Avatar
Mine has come on twice both times the dealership has just cleared the code. No problems yet
Sent from AutoGuide.com App
2012 F350 PSD Lariat FX4 CC single wheel. 5" stainless MBRP dpf back. Carli pintop w/ full deavers, long travel air bags, high mount stabilizer, Walker Evans street wheels 17x8.5s w/5.5 bs and 37x13.5 Toyo Open Country MTs
cumminchevy is offline
post #8 of 19 Old 05-13-2013, 05:56 AM
Quoted: 11 Post(s)
The "Check Coolant" message will pop up about every 15,000 miles. It varies a little depending on idle time/towing/hiway miles. So some folks will see it about every 13,000, Some at a longer interval.
The 6.7L uses a new coolant that Ford is gradually moving all engines to around the world. It will become their universal coolant in time. This coolant is not backward compatible with older designed engines. So it's only being used in newly designed engines. ( the coolant will eat the older style gaskets and seals)
The message pops up to remind the owner o check their coolant. This requires a test kit. You will check for Nitrites, Freeze Protection and new test for Reserve Alkalinity. (the first two test can be done with the older style test strips, The last test requires some new vials orange cap or clear cap depending on the coolant color)
Past generation of coolant all had Nitrites, So the test strips where looking for a positive indication, The new Speciality Orange coolant does not have any Nitrites and your test should show Zero for any Nitrites. If you test positive, you need to flush and refill your coolant system. Chances of this testing positive are really low unless somebody added the wrong kind of coolant when topping off the system
If you fail the Corrosion Inhibitor test. You can add the VC-12 Coolant Rejuvinator. 48 oz to the primary system and 20 some odd oz to the secondary coolant system. This adds Carboxylates to your coolant. This is basically a fatty acid that slowly coats all metal parts in the engine and prevents corrosion. You can add this twice during the coolants 105,000 mile life.
Things to remember,
1.You have two coolant systems, The check coolant test need to be performed on BOTH systems.
2. Coolant should be cool, Not hot when the test is done. Don't think you can drive20 miles and have your coolant at operational temps and do the test. Your truck will need to sit and cool off before the test can be done.
3. The test kits contain enough testing materials to do 10 test. They have an expiration date of about 2 years. So most owners will never use up a whole test kit.
4. If you dealer test your truck immediately, He didn't let it cool off. If he shows you one test strip, He didn't test both coolant systems, and he didn't perform all of the test. You need to use two of the old style test strips and two of the carboxylate test strips. So there should be 4 used test strips if he is showing you the results of the test.
Testing the coolant is not new. We did it on the 7.3L and added FW-16 if needed. On the 6.0L and 6.4L we tested and added VC-8 as needed and now with the 6.7L Ford just added a Check Coolant message to command center screen to remind us.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #9 of 19 Old 05-13-2013, 05:40 PM
What coolant are they moving to??
poormanscat is offline
post #10 of 19 Old 05-13-2013, 07:11 PM
Quoted: 11 Post(s)
Organic Acid Technology (OAT) or Ford calls it their Specialty Orange Coolant.
