New 2012 - some quick questions - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-04-2013, 04:47 AM Thread Starter
Hello everyone.
- I picked up the truck this week, saw a low tire pressure signal. So I had them looked at it, they just pumped the tires to make it go away. After driving about 50 miles, it alerts me again. Should I have them fix the hole/leak? I know they won't do a replacement, but man, it's brand new truck and tire(s) got leak(s) already. Hahaha
- AC system is not cold enough, compared to my f250 which is freeking cold. When I turn the seat AC on all the way up to max level, don't even feel a thing.
- I saw some oil change interval thread. But since I started this thread, might as well ask you guys too: the service advicer told me to change every 10k, because it has so much oil in it already, no need to change so frequently it'd break my bank. Thought? I also plan to go with synthetic oil. Even if the 10k (someone on here said 15k for synthetic), should I change it any sooner first time?
- idling: I had some old 6.0 trucks before, but not sure if we have to keep the truck idle while wait for something? What about warm up time in the morning?
- breaking in: do I have to? What to do? I already put in about 150 miles of easy running, and another 150 heavy towing (~10k lbs) in moderate hill/mountain.
Thanks
Nhi Nguyen
2012 Ford F350 CCLB King Ranch - stock
2012 Ford F250 RCLB, gasser: Prep to sale soon
2004 Toyota Tacoma RCSB: current commute when the SD one is not needed
2003 Ford F350 14' flat bed, 6.0L: Traded-in
2004 Ford F450 16' flat bed, 6.0L: Traded-in
2004 Ford F450 16' flat bed, 6.0L: Traded-in (yep, 2 of these)
2006 GMC 2500 Regular Cab LB, gasser: SOLD
2002 Chevy 1500 Extra Cab LB, gasser: SOLD
1998 Ford 1500 Extra Cab SB, gasser: SOLD
Hainhi is offline
post #2 of 7 Old 05-04-2013, 04:57 AM Thread Starter
I saw some info about breaking .
Will keep searching for the idle & warm up info. But it would be nice to have responds from you guys directly too, if you don't mind .
Nhi Nguyen
Hainhi is offline
post #3 of 7 Old 05-04-2013, 05:00 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I have had the same issue. What you have to do is air the tire way down then air it back to full again. Made mine go away.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 7 Old 05-04-2013, 06:08 AM Thread Starter
Hmmm, that might be a great idea. Probably because it's been sitting there at the lot for a long time
Nhi Nguyen
Hainhi is offline
post #5 of 7 Old 05-04-2013, 02:23 PM
BIG Laing's Avatar
A/C seats, not that cool
On the warming up part, I personally idle for at least 3 or 4 minutes (remote start) or until my engine oil at least 80°. Then I don't really drive her hard till she is warmed up. I know some guys that idle for 30 seconds and hammer down, never thought that was a good idea.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #6 of 7 Old 05-06-2013, 02:55 PM
raftdaddy's Avatar
I just got mine last week too,the manual says varying speeds for the first 1000 miles and no heavy towing for the first 500 miles.for break in.
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
post #7 of 7 Old 05-06-2013, 11:30 PM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Idle for 3-4 minutes and vary your speed for the first 1K miles! No heavy towing for the first 500 miles. Stay with conventional oil and change every 5K miles unless you are towing heavy all the time, then change every 3K miles. Hope this helps.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
