Do I have TPMS? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-03-2013, 04:05 PM Thread Starter
roustabout04's Avatar
Send a message via Yahoo to roustabout04
Do I have TPMS?
Wasnt exactly sure where to stick this topic so I figured "General" was as good a place as any.
Anyway on to the show...
I have a 2013 F-250. Im wondering if it came with TPMS. It doesnt say it anywhere on the window sticker that it does. Its an XLT package so that what im wondering. The reason im asking is because I was going to purchase some 18" wheels w/ 35" Trail Grapplers and i went to put them on and the front calipers on the top rubbed against the rim. So i took them back off and gave the tires back and stuck my factory 18s back on. The TPMS never came on. When the tire shop put the factories back on they put the wheels back on the incorrect corners that they came from when i bought it. I noticed after i crawled under the truck looking around. Anyway the TPMS still hasnt came on. So back to my question. Do all Super Dutys have TPMS or is that just for the more expensive packages?
Is it hunting season yet??
New
2014 CCSB Lariat FX4.
5" filter back, AFE drop in, and leveled.
Old
2013 CCSB FX4.
Leveled.
2005 CCSB FX4
Modded... Yes its fast... No you cant beat it...
roustabout04 is offline
post #2 of 8 Old 05-03-2013, 04:32 PM
rexrus's Avatar
Unless its a dually, yes, you have them. Any vehicle under 10,000lbs sold in the US since 2007 model year is required to have TPMS. If the truck was not cranked and moved far enough at the tire shop before the OE wheels were reinstalled, it probably never tripped computer for an error code.
Sent from AutoGuide.com App
rexrus is offline
post #3 of 8 Old 05-03-2013, 05:04 PM
RRF985's Avatar
When you remove the wheels and tires from the truck it will take the system a while to turn the light on. Since you put the wheels back on you won't get a light anyway.
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
post #4 of 8 Old 05-03-2013, 07:47 PM Thread Starter
Ok well that was quick. Thanks guys. Is there any procedure to completely disable the TPMS? Besides going with H&S which I'm not doing. Don't want to void the warranty and all. I've heard it's illegal for a dealer to disable it but if its anything like other "dealer only" procedures then the average Joe can git er done. Hopefully I'm not wrong. I want to go with aftermarket wheels and didn't want to break my factory tires and wheels apart just to get the sensors out.
New
Old
2013 CCSB FX4.
Leveled.
2005 CCSB FX4
post #5 of 8 Old 05-04-2013, 08:22 PM
Quoted: 13 Post(s)
Just buy some more sensors and install them in the new wheels. That's easier than trying to jailbreak your computer in the truck. Short of you buying an H&S or something similar that will crack the computer, You are stuck with TPMS.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #6 of 8 Old 05-05-2013, 06:23 AM Thread Starter
Has anyone priced TPMS sensors?
New
Old
2013 CCSB FX4.
Leveled.
2005 CCSB FX4
post #7 of 8 Old 05-05-2013, 06:36 AM
sirkdev's Avatar
check on ebay
sirkdev is offline
post #8 of 8 Old 05-05-2013, 09:07 AM
RRF985's Avatar
Buy a set of sensors and then get the the Ford TPMS tool. That way when you swap your wheels and tires you can train them yourself and not have to go to the dealer. The TPMS tool is like $40 from TireRack or check ebay.
-ARP head studs
-SCT SF3 w/ SRL+
-BPD FICM
-High Idle
RRF985 is offline
