Time to trade in the 2013 Platinum - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-30-2013, 04:40 AM Thread Starter
2013Platinum's Avatar
So I got home around 11:00 last night from work. Went to leave this morning to head back to work, around 8:15, battery is completely dead.
Lights were not left on, interior lights were off, very strange. Completely dead.
Time to trade it in! Just kidding, but seriously, ever had this issue?
also, I have a mini maxx (completely deleted), I have been that way for over a month now, and I have noticed my mini maxx does not shut off, the mini maxx is always on. Never had an issue before, but maybe?
Someone help
2013 F250 Platinum!
5 Inch MBRP Straight Pipe
S&B Intake
EGR Delete
Mini Maxx (DPF OFF)
2013Platinum is offline
post #2 of 16 Old 04-30-2013, 05:23 AM
should be a little switch on the box that the hdmi plugs into that is downline of the OBD plug. it says something like ON or BATT. Switch it to BATT.
mine is all zip tied up, i cant remember the exact wording though but BATT should make the mini maxx turn on and off when you cycle the ignition.
Tcm5080 is offline
post #3 of 16 Old 04-30-2013, 05:27 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Lol you got me for a second!! Hope you figure out your issue!!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #4 of 16 Old 04-30-2013, 08:00 AM
99powerstroke62's Avatar
Quoted: 54 Post(s)
Said no one ever... Lol
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #5 of 16 Old 05-01-2013, 12:02 PM
Quoted: 3 Post(s)
How did you get a "dpf removed" code? i read that u had to send in a form from the epa b4 h&s would give this out?? Thanx for any input...
Whskiles is offline
post #6 of 16 Old 05-01-2013, 03:05 PM
Quoted: 48 Post(s)
Your mini maxx isn't hooked up right, or you need to flip the switch on the OBD-II connector box
drunk on diesel is offline
post #7 of 16 Old 05-01-2013, 04:55 PM
Bryce18's Avatar
Quoted: 17 Post(s)
The "battery" switch position must be new??? I had to wire mine to a up fitter switch to get it to turn on and off with the key
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #8 of 16 Old 05-01-2013, 04:58 PM
WoodBoy's Avatar
If you have a offroad H&S they will give you a code for $100. You have to go through the epa stuff if you want to buy a new offroad tuner from H&S
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
http://www.powerstroke.org/forum/6-7...ustration.html
http://www.powerstroke.org/forum/6-7...round-2-a.html
WoodBoy is offline
post #9 of 16 Old 05-01-2013, 07:15 PM
Quoted: 48 Post(s)
not new... been that way since day one. The instructions tell you where to tap the power wire in the fuse box, but you can also tap the white/blue wire from the PTO bundle
post #10 of 16 Old 05-01-2013, 07:39 PM
Bryce18's Avatar
Quoted: 17 Post(s)
OK. I knew you could tap into the fuse box. But I just wired to a up fitter switch because it was easiest. I thought you guys mean there was a switch on obd port adapter that would make it turn on and off without wiring to a power source
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
