Regen question. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-25-2013, 03:36 AM Thread Starter
Ajc722's Avatar
Regen question.
New truck with 215 miles on it, get a console msg, exhaust filter cleaning. Mpg while cruise set went from 20.4 to 13. I thought the DEF handled that. And at 200 miles? 12 6.7 3.55 stock
Ajc722 is offline
post #2 of 5 Old 04-25-2013, 04:12 AM
Lococoin's Avatar
Send a message via MSN to Lococoin
Mine did it around the same mileage as well. Now I'm at 600 miles and lots of stop and go and it hasn't done it yet.
Lococoin is offline
post #3 of 5 Old 04-25-2013, 05:28 AM
Bullitt1289's Avatar
I've got almost 10k on mine and I've noticed a lot more regens with mostly city driving. You'll see your MPG decrease for a while after every regen also.
Sent from AutoGuide.com App
13 F250 FX4 CC Lariat Blue jean metallic
01 Mustang Bullitt #1289
02 F250 XLT 7.3 (sold)
SSgt USAF
Bullitt1289 is offline
post #4 of 5 Old 04-25-2013, 01:43 PM
ucpa111's Avatar
Quoted: 2 Post(s)
Regeneration is the act of "burning out" the particulates caught in the diesel particulate filter. Your engine pumps fuel in the exhaust stroke and raises exhaust temperatures to burn out the particulates that would otherwise simply go into the atmosphere. Thus, when the DPF is sensed as requiring cleaning, you use more fuel to burn it out.
Your truck uses diesel exhaust fluid (DEF) as part of selective catalytic reduction. The urea (DEF) is dosed into the exhaust stream to reduce nitrogen oxide (NOx). Check out this for some details.
http://media.ford.com/images/10031/S...rtreatment.pdf
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #5 of 5 Old 04-25-2013, 03:58 PM Thread Starter
Ajc722's Avatar
Great link. Thanks. Glad I am some what versed in chemistry. I'm kind of glad these new engines have this system, saw an older truck stomp on it and it bellowed black smoke like a locomotive. I thought to myself how obnoxious and the back of his truck was filthy.
Ajc722 is offline
