5th Wheel Load Capacity - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-22-2013, 01:28 PM Thread Starter
I have a 2011 F250 with the 6.7 diesel. Looking at getting a 5th wheel camper, just trying to fiqure out the towing capacity/Max camper weight I can pull safely. Thanks
HCFR34 is offline
post #2 of 3 Old 04-22-2013, 01:50 PM
Ajc722's Avatar
Just got a 2012, looking through the book it's 23500 GCWR. I have 3.55 gears and can bumper pull 14000lbs. 5th wheel is 15300lbs. Hope it helps chief.
Ajc722 is offline
post #3 of 3 Old 04-22-2013, 02:41 PM
Those numbers are correct. You are limited by payload, your payload will be in the range of 2k. That limits you to around a 10k trailer. Most people discard payload and just stay under the rear axle weight of 6100. So that will give you roughly 2500 in pin weight.
2012 f250 Ccsb Ultimate Lariat, Powerstroke FX4- Tuxedo Black, Bakflip F1
Lrdchaos is offline
