Check coolant additive light? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 11 Old 04-19-2013, 08:33 AM Thread Starter
This light came on at 12,000 miles. We will see what's going on in a few.
Countypig is offline
post #2 of 11 Old 04-19-2013, 10:17 AM
Blackie13's Avatar
Coolant additive
Mine came on at around 15k, since I have serviced myself I knew nothing was topped off or anything so I just reset through the command center on the dashboard. However 3 weeks later I saw antifreeze in the driveway. I ended up replacing the whole radiator due to a crack in the lower right side where the nozzle to empty is. Have no idea if the two are related or just a coincidence.
Blackie13 is offline
post #3 of 11 Old 04-19-2013, 10:45 AM
Same thing with mine. It comes on automatically at 12-15 thousand miles to remind you to test the coolant. I went to dealer to see if they had test kits and they don't. They told me to just reset it.
Sent from AutoGuide.com App
2011 F-350 CCSB
powerstroke43 is offline
post #4 of 11 Old 04-19-2013, 10:53 AM
you can either reset it in the computer or take it to the dealership and have the coolant check. They only charged me for the strips, and I have a record of it being checked for warranty if needed. Oh yea, they didn't find anything on mine. It had around 14000 miles on it. Do a search on here for more of the fine details of the system and reasons for the light. Good luck
Victor
vgostomski is offline
post #5 of 11 Old 04-19-2013, 12:59 PM
vlxjim's Avatar
Here you go. This is a post of mine on checking the coolant and what and where to buy it.
check coolant additive message
2011 F250 PowerStroke CCSB Lariat FX4 Loaded | Icon 2.5" Stage 2 | Icon track bar | Top Gun Dual Stabilizers | 20" Fuel Boost wheels +1 offset | 325-60-20 Hankook Dynapro ATm | RBP RX3 steps | BakFlip F1 Bed Cover | All Sales Mfg Fuel Door | Randy Ellis Light Bar | Hella Lights | aFe Magnum FLOW Pro-GUARD 7 Air Filter |
vlxjim is offline
post #6 of 11 Old 04-19-2013, 02:33 PM Thread Starter
After the dealership looking at my truck and testing it. They said that everything was fine and tested normal. They just reset it and sent me out the door. They did say that it was normal for the light to come on so that it cod be checked. Don't know why ford has to make the coolant system so tricky.
Thanks for the responses.
post #7 of 11 Old 04-19-2013, 05:58 PM
Your link is to something else
2011 F-350 CCSB
post #8 of 11 Old 04-19-2013, 06:40 PM
Works fine for me...
sobiloff is offline
post #9 of 11 Old 04-19-2013, 10:50 PM
That's strange, link works on my computer but on my phone it goes to something about adding a photo gallery from back in 2005.
2011 F-350 CCSB
post #10 of 11 Old 04-20-2013, 06:59 PM
Quoted: 10 Post(s)
This is nothing new.
On the 7.3L engines you needed to test and add the FW-16 additive
On the 6.0L and 6.4L you needed to test and add the VC-8 additive
On the 6.7L you need to test and add the VC-12 additive.
The additives have changed, as the engine blocks have changed and what needs to be protected has changed.
The new Specialty Orange coolant is a new World Wide standard coolant for Ford, that in time will become the standard coolant used on all Ford engine around the world. It is not backward compatible with older Ford engines. So as Ford designs new engines, it is designing them work with this new coolant.
Checking it every 13,000 to 15,000 miles is not that big a deal.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
