This knucklehead just poured a gallon of DEF in the - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 32 Old 04-18-2013, 06:22 PM Thread Starter
fuel tank because he was not paying attention to what he was doing. I have a half tank of fuel and a gallon of DEF sitting there. Thankfully, this moment of pure genious happened in my garage and not out on the road somewhere. Can I run this stuff through the engine or does this require a fuel tank drain? If the latter, can I take the fuel filter off on the frame rail and let the pump in tank push the fuel out into a large pan under the truck? Take the tank off the truck and dump it? Let's hear it guys and gals.
CamdenDawg is offline
post #2 of 32 Old 04-18-2013, 06:26 PM
DEF will ruin the entire fuel system if it makes it past the filters... I would not even run it thru the lift pump and contaminate the supply lines... Pull the tank and get it cleaned out right..
poormanscat is offline
post #3 of 32 Old 04-18-2013, 06:29 PM
Siphon as much fuel out as possible, then remove and drain the tank.
If you've turned on the key or started the engine since this fiasco, you'll need to replace the fuel filters.
Your engine and truck are expensive, so take the time and do it right.
Truckmaniac is offline
post #4 of 32 Old 04-18-2013, 07:16 PM
BIG Laing's Avatar
It's a $16,000 bill from Ford if you run DEF through your fuel system. Do what both these guys ^^^ said.
Do Not Start Your Truck!
BIG Laing is offline
post #5 of 32 Old 04-18-2013, 07:30 PM
350ninty7's Avatar
Good advise to drain that tank and not start the engine. Sorry to say but After you spend the money to have the tank drained you should spend another 16 dollars and buy a Stant ( Green) locking diesel fuel tank cap, so that ingenious person will have at least a chance of knowing DEF goes into the small hole that has the blue cap....
2012 F350 XLT 6.7 CC LWB SRW
11,500 GVW FX4 Off Road, Camper, & Prem XLT Options
2012 Montana Mountaineer 326 5th Wheel
SOLD and Missed
1997 F350 XLT 7.3 Liter Power Stroke
Reg Cab 4X4 Off Road Pkge
5 spd Manual with South Bend Clutch Upgrade
AFE Stage 2
Diamond Eye 3" Down Pipe 4" Exhaust Cat Delete
TW Tunes
WARN Winch
Original Owner 179,000 Miles
350ninty7 is offline
post #6 of 32 Old 04-19-2013, 03:28 AM Thread Starter
Started the engine for 20 seconds after it was poured in. Had
to move it since it was blocking the garage doors. Looks like I have a fun day of tank removal ahead of me. Whats the best way to clean the residue inside the tank and fuel line if any got in there? Hopefully none of it got as far as the first filter, if it even got in the fuel line. The line forms over on the right to kick my fanny.
post #7 of 32 Old 04-22-2013, 03:51 AM
Bad news, sorry to hear this. If you have full coverage from your insurance company, you can turn it in as accidental fuel system contamunation and have the dealership do the work and you won't effect your warranty or even get a Carfax.
Ask me how I know this! Not only am I an ins. agent but I put gas into a diesel tank and it was all covered.
Next time you hate on your insurance company, remember they insure stupid all day long!
jhall1957 is offline
post #8 of 32 Old 04-22-2013, 05:39 AM
You could just do some deleting and not have to worry about def anymore. These motors weren't meant to be all choked up!
Nathanc22 is offline
post #9 of 32 Old 04-22-2013, 07:46 AM Thread Starter
An update on the idiot (me) that dumped DEF in the diesel tank. I decided to let the Ford dealership drop the tank and drain it since they were doing a transmission pump replacement today anyway. Rolled it off a trailer Friday afternoon so that it would be ready for them this morning. Thought about doing it myself, but decided that it wasn't worth the hassle and that they would already have it up on the lift for the other work. Will update as necessary.
post #10 of 32 Old 04-22-2013, 08:54 AM
Bullitt1289's Avatar
how much are they raping your wallet for that?
13 F250 FX4 CC Lariat Blue jean metallic
01 Mustang Bullitt #1289
02 F250 XLT 7.3 (sold)
SSgt USAF
Bullitt1289 is offline
