Oil Change Question - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-02-2013, 03:19 AM Thread Starter
Oil Change Question
Going to do my first oil change on my truck. Do you guys fill the new oil filter with oil prior to installing it?
Also any other tips i should know first?
greenmntboy is offline
post #2 of 12 Old 04-02-2013, 02:30 PM
JuniorDiesel's Avatar
I have never filled the new oil filter prior to installation on my trucks. Once you install it and fill the motor with about 13 quarts of oil, run the motor for a little bit to get the fluids in all the right places to include the filter. Shut the engine off and let it sit for a little bit and check the oil level. Add oil if needed.
Sent from AutoGuide.com App
2007.5 Chevrolet Silverado LMM
MBRP Exhaust, Edge EVO CTS, Billstien 5100's, 18" XD Monsters, HID Lights (SOLD)
2012 Ford F-350 DRW
JuniorDiesel is offline
post #3 of 12 Old 04-02-2013, 02:41 PM
ucpa111's Avatar
Quoted: 2 Post(s)
Nope. I don't fill it. Seems like everything works just fine.
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #4 of 12 Old 04-02-2013, 03:23 PM
I always fill a oil filter if I can no matter what its on. You will build oil pressure a secound or two faster it seems. I figure the sooner the better.
Jason1Pa is offline
post #5 of 12 Old 04-02-2013, 04:51 PM
Quoted: 2 Post(s)
This. It surely doesn't hurt anything.
swiseuf is offline
post #6 of 12 Old 04-03-2013, 03:52 AM
sox3's Avatar
I always fill the filter before I install it. Just something I have always done. Its your choice as either is fine.
sox3 is offline
post #7 of 12 Old 04-03-2013, 09:31 AM
dslbrnr's Avatar
Why wouldn't you
SOLD 2012 F350 CC, SB, Lariat 4X4, 3.31's, E-Locker, Line-X'd
dslbrnr is offline
post #8 of 12 Old 04-03-2013, 11:11 AM Thread Starter
Thanks for the input. I have never filled one up before. I read it somewhere so i thought i would ask.
post #9 of 12 Old 04-03-2013, 11:33 AM
Bonesman's Avatar
The way I see it is it only takes a minute to do so you might as well. One thing is for certain is that there's no negative outcome by doing it.
6.7 F250 Lariat FX4: ICON 4.5", MHT Fuel Throttle, Toyo 35 A/T 2, Rigid 20" combo
6.0 F250 Lariat FX4
Bonesman is offline
post #10 of 12 Old 04-03-2013, 08:00 PM
350ninty7's Avatar
Always filled the filter with one quart of oil every oil change for 15 years on my 7.3. On the 6.7 it takes 13 qts so Look at it this way, you buy (3) 1 gal jugs plus one quart to equal 13 qts, that 1 quart bottle goes into the oil filter before install. Simple eh.... oh, just don't knock the filter over when you are crawling back under the truck, makes for a mess.
2012 F350 XLT 6.7 CC LWB SRW
11,500 GVW FX4 Off Road, Camper, & Prem XLT Options
2012 Montana Mountaineer 326 5th Wheel
SOLD and Missed
1997 F350 XLT 7.3 Liter Power Stroke
Reg Cab 4X4 Off Road Pkge
5 spd Manual with South Bend Clutch Upgrade
AFE Stage 2
Diamond Eye 3" Down Pipe 4" Exhaust Cat Delete
TW Tunes
WARN Winch
Original Owner 179,000 Miles
350ninty7 is offline
