Horn Noise above 60 mph - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-25-2013, 06:50 PM Thread Starter
rolltideroll989's Avatar
I am experiencing a humming noise from the dash that sounds similar to a horn at speeds anywhere from 60mph and above. They dont occur all the time but it can get very annoying. Below is a link to what the noise sounds like.
Have any of you experienced this issue, and have any suggestions as to what it could be?
rolltideroll989 is offline
post #2 of 11 Old 03-25-2013, 10:03 PM
BIG Laing's Avatar
There have been alot of cases of a leak around the windshield. Something to do with a gasket, or rubber seal not working.
Search "windshield Leak" in the 6.7 section, and you will find some threads about it.
BIG Laing is offline
post #3 of 11 Old 03-25-2013, 10:10 PM
brstanle's Avatar
I've had that noise on a couple vehicles, and it always coincided with having a new windshield put it. It would eventually subside. If that's not the case, then my other idea involves digging into the bowels of the dash. Unless you want to remove more of the skin from your hands and forearms, i would suggest taking it to the dealer.
brstanle is offline
post #4 of 11 Old 03-26-2013, 03:17 AM
6.0f250firstcar's Avatar
Sounds like the notorious windshield seal.
Ryan
6.0f250firstcar is offline
post #5 of 11 Old 03-26-2013, 04:38 AM
Re: Horn Noise above 60 mph
Have you sped through a carnival parking lot lately?!
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #6 of 11 Old 03-26-2013, 06:44 AM
6.0L Stroker's Avatar
Mine has done it when going about 80 or above. And my dad said his 450 did it on the way home from Mississippi I guess it was windy.
Sent from AutoGuide.com App
2011 F350 CC/SB Bronze and Gold KR tinted windows, spray in bedliner. MBRP 5in filter back with 6in tip and Mini Max. S&B Dry Intake, TGC Dual Stabalizer.
Sold 2004 Ford F-350, cc/lb Lariat, Procomp 6.5 lift with 37/13.5/17 Toyo Mts, Id tuned Ficm, Bully Dog Triple Dog, MBRP all the way back,
6.0L Stroker is offline
post #7 of 11 Old 03-26-2013, 05:42 PM
Mine does it on the Interstate in a strong cross-wind.
mindenf250 is offline
post #8 of 11 Old 03-31-2013, 09:04 PM
8upbowhunter's Avatar
Mine does the same thing with a strong crosswind.
2011 Ingot Silver F250 XLT 6.7L PSD SB CC FX4 3.31 Gears
8upbowhunter is offline
post #9 of 11 Old 04-01-2013, 07:41 AM
same here..... its really bad when its cold outside
blacknight is offline
post #10 of 11 Old 04-01-2013, 11:36 AM
Door molding
My 2011 was doing this exact thing.
If you open the drivers side door and look to the front, there is a triangle piece of black molding. There are several plastic retainers that hold it in place. 2 of my retainers were out and the molding was loose. I snapped them back into the door frame and the noise went away. Hope this helps. See the pic above - sorry could get it to rotate.
ames is offline
