Help passenger front higher than driver side! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-24-2013, 05:28 AM Thread Starter
salnazzaro's Avatar
Quoted: 19 Post(s)
Ok so I had a 2.5" coil spacer leveling kit installed andi just noticed my front looks out of wack, I measured it and the passenger side is 1.5" higher than the driver side! It's brand new what the hell do I do! I just saw in the new diesel power that they installed a 6" pro comp lift on a new f250 and they even noted the drivers side was an inch lower! What do I do!
2015 f350 cclb platinum...5% tint, Anzo smoked mirror lights, recon clear cabs, tgc 2.5" spacers, carli adjustable track bar, icon 5" rear blocks, Firestone riderites, B&W goosneck, line x, rancho 7000s, Fuel Mavericks wrapped in Toyo MT's, 4" flo pro straight pipe, Sct w gearhead tunes, hideaway LEDs
salnazzaro is offline
post #2 of 12 Old 03-24-2013, 07:41 AM
JRW6.7's Avatar
Make sure the installer oriented the springs on the spacers correctly. Either way I would take it back to them. One side shouldn't be higher.
JRW6.7 is offline
post #3 of 12 Old 03-24-2013, 07:47 AM Thread Starter
salnazzaro's Avatar
Quoted: 19 Post(s)
I just checked the springs, the end of the top of the spring is set in the notch of the rubber spacer and the bottom of the coil the end is at the notch there too, I had it aligned and the adjustable track bar was adjusted so I don't know what else to do
post #4 of 12 Old 03-24-2013, 07:57 AM
JRW6.7's Avatar
Spacer kits are pretty simple and straight forward. Other than what I already mentioned, not sure what else it could be. I'm sure your truck was on a level surface when you measured, so I won't even go there. If anyone else has any ideas, I would like to hear them too. If you paid someone to do the work, I would take it back.
JRW6.7 is offline
post #5 of 12 Old 03-24-2013, 08:00 AM
Major Senior Member
HoustonRider's Avatar
Assuming it was the same height on both sides before the level, then I would have to go with the springs aren't seated right on both sides. You can jack it up all the way and spring the spring ( if they are not seated right) or take it back.
Sent from AutoGuide.com App
2012 F250 6.7 FX4 Ultimate
2012 F150 Eco FX4 Crew
2011 F250 6.7 FX4 Ultimate/sold
2009 F250 6.4 King Ranch FX4/sold
2011 F150 6.2 Raptor Crew/sold
HoustonRider is offline
post #6 of 12 Old 03-24-2013, 08:10 AM Thread Starter
salnazzaro's Avatar
Quoted: 19 Post(s)
So just jack the front up on the frame and see if I can reposition the springs?
post #7 of 12 Old 03-24-2013, 08:38 AM Thread Starter
salnazzaro's Avatar
Quoted: 19 Post(s)
Ok just checked at my parents and drivers side is 1" lower than the passenger side which is what diesel powers f250 was before they installed a pro comp 6" lift, is tips a factory ford problem then?
post #8 of 12 Old 03-24-2013, 02:41 PM Thread Starter
salnazzaro's Avatar
Quoted: 19 Post(s)
ok so heres some stock height pics
Name:	2013 stock height 1.jpg
ID:	86922   Click image for larger version
Name:	stock height 2.jpg
post #9 of 12 Old 03-27-2013, 06:43 AM Thread Starter
salnazzaro's Avatar
Quoted: 19 Post(s)
We're throwing my truck on the lift today and start measuring to see if anythings out of whack
post #10 of 12 Old 03-27-2013, 08:23 AM
Skyd Ram's Avatar
Quoted: 63 Post(s)
My 08 and my '11 were both about an inch low on the drivers side. I assume that it is due to the additional weight on the drivers side. Fuel tank, DEF tank, steering gear, etc.......
I remember seeing a 1" block in Fords part system for the rear to compensate. My parts guy says that he never remembers selling one but that he assumed that it was for customers that complained about it. I measured a few '12's at the dealer one day and they we all a bit low on the drivers side and that was with almost empty tanks.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
8LUG Truck Gear
888-886-2480
Find us on Facebook
Skyd Ram is offline
