level kit with airbags? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 12 Old 03-23-2013, 03:56 AM Thread Starter
hey guys i ordered my air bags for the rear of my f250 already but havent installed them yet, and now im thinking i may want to add a leveling kit to the truck, is this possible still while using the air bags as well? i know some kits just do the front and some do front a rear...what do you guys suggest?
Bopper is offline
post #2 of 12 Old 03-23-2013, 05:35 AM
mach14604's Avatar
I am doing this exact thing in a couple of weeks. I just ordered my airbags last night. I am doing Pro Comp 2.5 level in the front. From what I was told by Pro Comp is that if I just did the front I don't have to do the back and it won't look funny. They told me the only time I will notice difference in front and rear level is when I tow. But then I am going to air the bags anyway so it does not really matter it will still be level.
Want to Buy Ford Racing M-55 Exhaust
mach14604 is offline
post #3 of 12 Old 03-23-2013, 08:13 AM
I'm doing the exact same, are you going with extended shock mounts and castor wedges or adjustable trackbars to correct castor?
Take a stand today, join your local Fire Department or First Responder/Rescue team. We need all the help we can find!
Ken2012f350 is offline
post #4 of 12 Old 03-23-2013, 08:19 AM
majek5's Avatar
I leveled my 06 and then added bags. Just for towing, so it doesn't look like it's butt is draggin. Plus, I think it smoothed out the ride a little. Granted the 6.7 rides smoother than an 06, so you may not see much difference there.
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #5 of 12 Old 03-24-2013, 09:21 AM
cd4899's Avatar
I did a Readylft 3.5" lift which does both the front and rear. I also have the airbags. You will just have to add a spacer for the bags that I got from Firestone. You will love the bags! Great for towing but will smooth out the ride as well when empty. I run mine on 10psi all of the time while empty.
2012 F350, Lariat, FX4, CCSB, ReadyLift 3.5" SST, 37" Toyo Mt, BMF Novakanes 20x9's, Firestone air bags, Air-Lift 72000, Rigid D2's
cd4899 is offline
post #6 of 12 Old 03-24-2013, 10:50 AM
mach14604's Avatar
Extended shock mounts is what the kit comes with.
post #7 of 12 Old 03-25-2013, 09:12 PM
Do you know how high you can go while using the spacers?
*SOLD*2008 F250 6.4: H&S Mini w/ Bully dog mount, Flo-Pro DPF/CAT delete, AFE stage 2, Viper 5901 Remote start.
2012 F250 6.7: S&B CAI, H&S Mini Maxx, 5" MBRP straight exhaust, Firestone airbags.
Grunnsetning is offline
post #8 of 12 Old 03-27-2013, 06:45 AM
cd4899's Avatar
I know that u can go pretty high. Firestone makes many different sizes of spacers. Contact SD Truck springs. They can give u all of the info. That's where I bought mine and they are very knowledgeable.
cd4899 is offline
post #9 of 12 Old 03-27-2013, 10:21 AM
barobbin's Avatar
what compressors are yall runnin?
barobbin is offline
post #10 of 12 Old 03-27-2013, 05:33 PM
cd4899's Avatar
Air lift 72000...set it and forget it. Plus change on the fly adjustability. A bit pricey but was worth the extra $ to me.
cd4899 is offline
