Exhaust filter percentage always at 0% - Ford Powerstroke Diesel Forum
Old 03-20-2013, 02:30 PM
Hello ive been monitoring the exhaust filter percent and I haven't seen it change from zero. I pulled drove 170 miles today in all sorts of conditions and it stayed at 0 all day. I know ive seen it move before so its got me thinking. Anyone else have this problem?
Truck is '12 regular cab DRW...pulls like a champ! The 6.7 puts the 6.4 to shame (stock)
Old 03-20-2013, 02:39 PM
pick of said truck and its load today.
Old 03-20-2013, 03:03 PM
drive it and enjoy
Old 03-20-2013, 04:13 PM
If your working it hard enough, and the EGT's are high enough, your truck does a passive regen, and burns soot without telling you. That could explain it.
You still have a DPF right?
Old 03-21-2013, 05:28 PM
What are you monitoring it with?
Old 03-21-2013, 06:11 PM
A couple of the PIDs on the Edge Insight don't work or only show values at start up. Watch the Soot % it works.
As stated, Towing where you have EGTs above 572° will perform a passive regen and you will actually see the Soot % drop.
Old 03-22-2013, 06:23 AM
Truck is completely stock with 4500 miles. I monitor it with the display on the speedometer. (it doesnt have the bigger lcd screen, xl package) Just hit info on the steering wheel and it cycles through.
I understand about the passive regeneration but I did idle the truck for a good half hr and the percentage never changed. In the past I have monitored the % and it jumped around quite a bit. I just dont see how it could always be at 0% unless a sensor is messed up or its always cleaning exhaust filter (my real concern)
Old 03-22-2013, 06:40 AM
I have the LCD screen and there is no way to monitor soot
Old 03-22-2013, 06:46 AM
Really? I ordered it with the OCR (operator command regeneration) option, maybe is has something to do with that? I will take a pic and show what it looks like.
Old 03-22-2013, 11:44 AM
that must be it because i dont have that option on my screen either. it only tells me if the fluid is ok or under half.
