TPMS light? - Ford Powerstroke Diesel Forum
Old 03-04-2013, 04:34 PM
TPMS light?
2011 F250 6.7 XLT. I just bought a set of stock 20s to replace my 17s. I took the truck to ford to have the tires installed, i was told that the computer could not be programmed to the right speed and it would be off about 3 MPH. The tires came with sensors and they just need to be programmed. Now my TPMS light came on and says TPMS fault on my screen. Has anyone done what im doing and had these issues? Yes i do have 3.31 gears. Little help of what i need to do? thanks
Old 03-04-2013, 04:48 PM
did u reuse sensors or did the stock 20's rims have them?
I can't believe they can't program for such a small tire size change
good luck
Old 03-04-2013, 04:55 PM
TPMS light
The stock 20s had three so i had one installed. So no im not using the sensors from the 17s, if thats what your asking? The guy i bought the 20s from need to keep one for his new tires.
Old 03-04-2013, 05:04 PM
did ford program for that tpms swap ?
Old 03-04-2013, 05:07 PM
anything here ??
looks like a pain LOL
TPMS reset procedure
The TPMS reset procedure needs to be performed after each tire
rotation on vehicles that require different recommended tire
pressures in the front tires as compared to the rear tires.
WARNING: To determine the required pressure(s) for your
vehicle, refer to the Safety Compliance Certification Label or
Tire Label located on the B-Pillar or the edge of the driver’s door. See
Vehicle loading - with and without a trailer in this chapter for more
information.
Overview
To provide the vehicle’s load carrying capability, some vehicles require
different recommended tire pressures in the front tires as compared to
the rear tires. The tire pressure monitoring system (TPMS) equipped on
these vehicles is designed to illuminate the low tire pressure warning
light at two different pressures; one for the front tires and one for the
rear tires.
Since tires need to be rotated to provide consistent performance and
maximum tire life, the tire pressure monitoring system needs to know
when the tires are rotated to determine which set of tires are on the
front and which are on the rear. With this information, the system can
detect and properly warn of low tire pressures.
TPMS reset tips:
• To reduce the chances of interference from another vehicle, the TPMS
reset procedure should be performed at least three feet (one meter)
away from another Ford Motor Company vehicle undergoing the TPMS
reset procedure at the same time.
• Do not wait more than two minutes between resetting each tire sensor
or the system will time-out and the entire procedure will have to be
repeated on all four wheels.
• A double horn chirp indicates the need to repeat the procedure.
Performing the TPMS reset procedure
It is recommended that you read the entire procedure before attempting.
1. Drive the vehicle above 20 mph (32 km/h) for at least two minutes
and then park in a safe location where you can easily get to all four tires
and have access to an air pump.
2. Place the ignition in the off position and keep the key in the ignition.
Tires, Wheels and Loading
3. Cycle the ignition to the on
position with the engine off.
4. Turn the hazard flashers on then
off three times. This must be
accomplished within 10 seconds.
If the reset mode has been entered successfully, the horn will sound
once, the TPMS indicator will flash and the message center (if
equipped) will display TRAIN LEFT FRONT TIRE. If this does not
occur, please try again starting at Step 2.
If after repeated attempts to enter the reset mode, the horn does not
sound, the TPMS indicator does not flash and the message center (if
equipped) does not display TRAIN LEFT FRONT TIRE, seek service
from your authorized dealer.
5. Train the TPMS sensors in the tires using the following TPMS reset
sequence starting with the left front tire in the following clockwise
order:
• Left front (Driver’s side front tire)
• Right front (Passenger’s side front tire)
• Right rear (Passenger’s side rear tire)
• Left rear (Driver’s side rear tire)
6. Remove the valve cap from the valve stem on the left front tire;
decrease the air pressure until the horn sounds.
Note: The single horn chirp confirms that the sensor identification code
has been learned by the module for this position. If a double horn is
heard, the reset procedure was unsuccessful, and must be repeated.
7. Remove the valve cap from the valve stem on the right front tire;
8. Remove the valve cap from the valve stem on the right rear tire;
9. Remove the valve cap from the valve stem on the left rear tire;
Training is complete after the horn sounds for the last tire trained
(driver’s side rear tire), the TPMS indicator stops flashing, and the
message center (if equipped) displays:
TRAINING COMPLETE.
10. Turn the ignition off. If two short horn beeps are heard, the reset
procedure was unsuccessful and must be repeated.
If after repeating the procedure and two short beeps are heard when the
ignition is turned to off, seek assistance from your authorized dealer.
11. Set all four tires to the recommended air pressure as indicated on
the Safety Compliance Certification Label or Tire Label located on the
B-Pillar or the edge of the driver’s door. See Vehicle loading - with and
without a trailer in this chapter for more information.
__________________
Old 03-04-2013, 05:10 PM
TPMS light
Yes. I was also told that the tech called ford hotline to get advice about reprogramming the computer to calibrate the speed and for told him that you cant do it and it would void the warranty? They aslo said the truck was not made for 20s.
Old 03-04-2013, 05:11 PM
Just go through the training routine in your owners manual to build a relationship between your new TPMS sensor and your truck.
As far as your new wheels. The Ford computer will not support 20" wheels with your 3.31 rear end. So don't select the 20" wheels but rather choose the largest TIRES that are listed for the 17 or 18" wheels. That will be as close as you can get. The factory 20" rims ( 275/65R20) are 34.4" in diameter. See if any of the 18" tire selections will come close to the diameter.
Like maybe the 295/70R18 if the computer goes that tall.
Old 03-04-2013, 05:15 PM
TPMS light
I tried the reset procedure, did it about 4 times and the screen said it could not be done, everytime.
Old 03-04-2013, 05:16 PM
well heck ,,,,
Old 03-04-2013, 05:18 PM
I read that discount tire has a scanner to isolate the bad sender
not sure if you have a bad one ? but throwing it out LOL
