Anyone else getting turbo surge? - Ford Powerstroke Diesel Forum
Old 01-10-2013, 02:38 PM
I just recently deleted with a DPF delete, H&S mini, & EGR delete. I also have an S&B intake. Well every once in a while ill get some turbo surge like I used to on my old 7.3. It usually only happens when I'm barely getting into it to speed up, or I let off the gas quick.
I know the turbos on the 11s are bad, and some on the 12s as well. I didn't know if this was part of the problem with the turbos or if it is just like on the 7.3 with just an annoying bark. I don't want to have the warnings of a bad turbo, and not know what I am looking for.
I know on the 7.3 they had a new compressor wheel to fix the problem and add a little boost. Has anyone heard of anyone doing one of these for our turbos?
Sent from my iPhone using AutoGuide.com Free App
Old 01-10-2013, 03:45 PM
Well, the compressor surge when letting off of the throttle could be solved by maybe replacing the Recirc. valve. As far as the under-load surge, i'm not sure given my unfamiliarity with the turbos.
Does it still do it under lower boost? Have you replaced any piping?
Old 01-10-2013, 04:33 PM
No piping has been replaced, and yes it is usually at low boost.
Old 01-10-2013, 05:12 PM
Now your scaring me... I have noticed it twice on mine. First time I noticed it was on the freeway cruising at 65 MPH and I could hear the engine surging. Looked at the boost PSI and it was bouncing from 5-8 PSI back and forth. Did this for about 30 seconds (felt like an eternity). It stopped after I let off the gas for a second and then gave it some throttle to about 15 PSI. Then it settled back down at a constant 6.
2nd time was right after a regen started. 40 MPH cruise set, did it for about 30 seconds again and stopped.
I am all stock and under warrenty till 100K on the motor/turbo right?
Painted horse where are you? We need your knowledge...
Old 01-10-2013, 05:15 PM
Sounds like a turbo-dynamics issue. Try resetting the tune?
Old 01-10-2013, 05:29 PM
[QUOTE=BIG Laing;3520641]Now your scaring me... I have noticed it twice on mine. First time I noticed it was on the freeway cruising at 65 MPH and I could hear the engine surging. Looked at the boost PSI and it was bouncing from 5-8 PSI back and forth. Did this for about 30 seconds (felt like an eternity). It stopped after I let off the gas for a second and then gave it some throttle to about 15 PSI. Then it settled back down at a constant 6.
Yeah that's about the same as what mine is doing.
You should still be under warranty, so I would take it in and ask. It couldn't hurt to ask. Maybe the answer could ease all our minds.
Old 01-10-2013, 05:30 PM
I may try that tomorrow when I'm putting my EGT kit on.
Old 01-10-2013, 06:10 PM
If it's something like a Boost Control Solenoid, resetting the ECU will be a good place to start, definitely a hell of a lot cheaper/ easier than buying or swapping parts.
Old 01-10-2013, 10:14 PM
I will take it in saturday afternoon, and see what they say.
Old 01-11-2013, 01:01 AM
You aren't running a KEM tune are you? My boost oscillated like crazy with the KEM tunes in there. Got rid of that tune and it ran fine.
