how many miles until u need to refill the D E F - Ford Powerstroke Diesel Forum
Old 11-09-2012, 06:37 PM
so have 2400+ miles no towing yet just driving to work and where ever else, just checked the system info out and said under 1/2 way thought the fluid was suppose to last 7500 what is everyone else's miles before filling
Old 11-09-2012, 06:48 PM
Its about a gallon every 1000 miles. Most people I know top it off when they do their oil change. (5K mile oil changes BTW)
Old 11-09-2012, 06:49 PM
And it's possible Your tank wasn't topped off to begin with...
Old 11-10-2012, 01:14 AM
I topped my tank off at 1000 miles, about 2.5 gallons. At the oil chage, 5000 miles, I topped it off again. Just over 2.5 gallons, so, it probably wasn't full at the beginning. It will vary with your style of driving. Also, remember the tank has a heater, not the fill neck. So, if you live in the cold country, just add 2.5 gallons and go.
Old 11-10-2012, 04:10 AM
I top mine off every month and have since New.
Old 11-10-2012, 05:52 PM
2.5 gallons every 4k
Old 11-11-2012, 07:35 AM
Towing a heavy trailer will change things dramatically!!
I pulled my 5er from central Texas to Colorado & back, about 1700 miles, and it burned nearly a full tank. We were directly into the wind a lot, and Raton pass was quite a long hard pull too.
Mark
Old 11-11-2012, 07:52 PM
I've heard from several sources that they don't fill the DEF tank completly full from the factory. Probably only 1/2 to 3/4 full from the factory. I'm at 5600 miles now and mine says that its under half full. I will just keep going until it tells me to put more in.
Old 11-15-2012, 03:32 PM
When i bought mine new (with 25 miles on it) I had the refill DEF message at 300miles. I just topped off my tank this past weekend and used a half of box of BLUE DEF and i just clicked 6000 today. So I guess take that for what its worth.
Old 11-15-2012, 03:36 PM
I used my truck to tow and I'm getting about 1000-1200 miles per gallon of DEF. If you don't use your truck for what it is intended for, you will use far less DEF.
