Synthetic Oil - Ford Powerstroke Diesel Forum
Old 08-02-2012, 09:02 PM
Synthetic Oil
What brands of synthetic oil is everyone using? What oil filters? How many mile between changes?
I searched the forum and did not find this in any discussion.
Sent from my iPad using Autoguide
Old 08-03-2012, 06:07 AM
I think any synthetic is worth the money but just to be sure I get my moneys worth I use AmsOil 5w40 Diesel oil. I have 12000 miles on it so far and plan to do an oil analysis at about 15,000. If the analysis comes back good I will run it another 10,000 and change it. I am a firm believer that changing oil every 3 - 5000 miles is a waste of money - but it won't hurt anything either.
Old 08-03-2012, 07:27 AM
Do you change out your filter at all during that time?
Old 08-03-2012, 10:56 AM
Are you running a bypass? When I looked into extended intervals and Amsoil with my Dodge, most people were running the Amsoil bypass filter. Could have something to do with the lower capacity of the Cummins as well?
Old 08-03-2012, 08:53 PM
I haven't got a bypass filter installed - just using an Amsoil full flow filter. I am planning on changing the oil every 25,000 miles so I am not expecting to need a bypass filter but I guess I'll have a better idea after I send the oil off for analysis.
Old 08-04-2012, 07:19 AM
What lab are you sending your oil to?
Old 08-04-2012, 07:40 AM
I use Amsoil and just change the filter every 10k and add a quart and change oil at 30k
Sent from my ADR6400L
Old 08-04-2012, 07:46 AM
Most use Blackstone Labs
Rotella T6 5-40 for Me oh and only Motorcraft filters from dieselfiltersonline.com
Old 08-04-2012, 07:45 PM
I plan to use http://http://www.polarislabs.com/oil-analysis.php in Edmonton. They also have US locations.
Old 08-08-2012, 08:24 AM
Have you sent the oil out for an analyses? I just starting running Amsoil as well.
