| General 6.7 Discussion General 6.7 Discussion |
Tire sizes?
I'm sure it's been asked a thousand times but I couldn't find the answer by searching. I have a 2012 250 with 20" stock wheels. Without altering the lift/suspension, how large of a tire can I put on the factory wheels and not rub?
35s is about all you can do and really you need a leveling kit once they start getting wide which most of the tires are. Very few 12.5s to choose from.
A 35 12.5 20 will fit np. I think you'll find there's nothing but a mudder available in that size. |
Ok, thanks. You mentioned a leveling kit. Is that similar to the levelers I put on my 1/2 ton? Only in the front to bring the nose up a little? Or is the levelers your talking about more of a lift kit?
Thanks again Don |
The 20" michelin 275/65r20 are 34.4" tall, So 35" tall tire is not a whole lot bigger than the OEM tire. The problem as Trick mentions is the width and wheel offset that cause problems.
FYI: just found out yesterday I can no longer go thru a car wash. Tires are too wide for the track and it got stuck.
D'oh. |
You go thru car washes.
I gave up on those years ago when I got my first long bed. Found out most car washes will not handle a CC long bed. |
my 295 60 20's fill up the wheel nicely.
I have KMC 8.5 by 20 inch wheels. |
Yea, we've got one that's pretty cool. It's a general all over wash and when it comes out all wet the Mexicans swarm it and it's all sparkly in like 5 minutes.
Sad I can't go there anymore. |
