| General 6.7 Discussion General 6.7 Discussion |
2011 F-250 Bumper bolt Torque Specs ????
I have a 2011 F250 LB 4X4 that was involved in a small mishap couple days ago.. I got a new front bumper from Ford and tomorrow plan on installing it. Does anyone know the torque spec's for the bolts involved? I have no idea how many there are either... Thanks in advance for any help
I just had to pull mine to install a grill guard. There are 2 bolts on each side of the tow hooks and also a bracket Infront of the tires that you have to take off. I learned the hardway to remove the rubber flap connected to your inercooler before you try to take the bumper off. If I remember right to torque on the main bolts was 50-55 lbs but I could be off a bit. Also disconnect ur fog lights if you have them. There is an idiot plug in about the center of the truck under the radiator. Hope this helps.
