| General 6.7 Discussion General 6.7 Discussion |
We don't have "exhaust brakes"!!
Ever since I got my truck I've been really disappointed with the "exhaust brake", or should I say lack thereof. An exhaust brake increases exhaust back pressure and makes the engine harder to turn due to the work needed by the pistons to push the exhaust out against that pressure.
The dodge and chevy trucks increase exhaust back pressure by closing the turbo veins. This would increase the turbo speed and create boost, no? There is no such increase in boost in my truck, aside from the normal increase of a few pounds that you get in any turbo diesel engine when down shifting. My truck down shifts, but there is no additional resistance that I can detect in addition to the shift. NONE!!! I'd bet the engineers didn't really put one in this truck because it would turn the turbo faster and this turbo is pretty weak. That's my best guess. |
i think its more of an engine brake, thats what my ecoboost 150 had when in tow/haul it just downshifted soon and reved up the rpms to slow it down and did it more based on how hard u pushed the break down
Haven't towed with my truck but I will post back when I do. I know someone that used their powerstroke for work and tows all the time. He said his works great.
your truck uses a coast clutch inside the trans to provide additional engine braking. Much safer than the exhaust brakes you mentioned. It works very well and is calibrated through the PCM based on load and driver input.
Closing the veins wouldn't necessarily increase boost. If there's no exhaust flow or a small amount of exhaust flow then there's nothing to spool the turbo up. Shutting down the veins just restricts the flow.
Creating boost is counter productive to engine braking as that boost pressure is trying to turn the engine on the intake stroke.
I don't know that it's actually exhaust braking, but in tow/haul mode the truck does very well in braking a heavy rig going downhill. And the anti-sway stuff and anti-lock stuff really works well. I've had occasion to use it when some little sports car forgets the laws of physics.
making boost is further restriction on the turbo
the 6.7 Cummins exhaust brake is a beast and is perfectly safe. It works awesome, the turbo screams and it does produce boost |
The exhaust brake on the Cummins works best in conjunction with the tow/haul mode. It will actually stop the truck. You can hear the exhaust brake working. Does the Ford 6.7 work similar. |
