School me! need new gears with 37's? - Ford Powerstroke Diesel Forum
post #1 of 27 Old 06-14-2012, 11:02 AM Thread Starter
M3NNIS's Avatar
ok enlighten me please. I tried to search but not sure what to search for. if you can answer or direct me to a thread that has already answered.
I am putting 6 inch and 37's on my 2012 F250 short. Do I need to change gearing?
I will tow a boat and a camper. I also daily drive the truck.
along with that. please tell me what the different gearing numbers reference.
thanks.
2012 F250 4x4
M3NNIS is offline
post #2 of 27 Old 06-14-2012, 11:17 AM
Quoted: 48 Post(s)
what is your current gear ratio?
drunk on diesel is offline
post #3 of 27 Old 06-14-2012, 12:07 PM
bltp203's Avatar
If you have 3:55 then you should be fine.
2012 F-350 CCSB 4X4, plow package, Skyjacker 1" leveling kit, 295/70/18 Nitto's
bltp203 is offline
post #4 of 27 Old 06-14-2012, 12:13 PM
bartburns's Avatar
I have the 3.55 gears and 37's. I tow an 11k lb trailer with no issues. I am normally turning around 1600 RPM at 80 w/ no load. (note....the speedo says ~73 when I am doing 80).
2015 Platinum F250. 6.7L 6 inch Fabtech Coilover 4 link w/ rear traction bar. 37x13.50R22 Toyo MT's on Fuel Lethal's, Royalty Core Grill, Dual mini DS 2.0 Morimoto projectors
bartburns is offline
post #5 of 27 Old 06-14-2012, 02:16 PM Thread Starter
M3NNIS's Avatar
yes, I have 3.55.
are you able to re calibrate the speedometer, or does changing the gears fix the speedo?
2012 F250 4x4
M3NNIS is offline
post #6 of 27 Old 06-14-2012, 04:28 PM
Originally Posted by buschy View Post
yes, I have 3.55.
No on both accounts
Matt
2011 F350 6.7L CC/LB SRW 4x4 King Ranch White Tri Coat
31 YNOT is offline
post #7 of 27 Old 06-15-2012, 12:08 PM Thread Starter
M3NNIS's Avatar
so no way to fix the speedo? that sucks. and the general consensus is that 37 will be fine with 3.55 gears?
2012 F250 4x4
M3NNIS is offline
post #8 of 27 Old 06-15-2012, 04:02 PM
bltp203's Avatar
If you were running 20" rims from the factory then that is tallest the computer will accept. Mine came with 18's, so when I bumped up to 295's, I had the dealer set the truck for 20" wheels and 275/70/20's and now I am only .5 mph off.
bltp203 is offline
post #9 of 27 Old 06-15-2012, 04:29 PM
I think the max they can set the tire for in the software is 34"
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #10 of 27 Old 06-15-2012, 04:30 PM Thread Starter
M3NNIS's Avatar
none of the tuners or any other way to do it?
2012 F250 4x4
M3NNIS is offline
