Stupid NooB question........ - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 8 Old 03-22-2012, 08:40 PM Thread Starter
ulev1st's Avatar
Tried a search..came up with notta so here goes..
I have a 12 F250 FX4 with the trailer package andthe cab clearance lights..I want to install the tri bar lights that come stock on the dually under the tailgate. Does anybody know if the truck is prewired for these..also anybody have a ballpark price...it's the middle of the night and I'm stuck at work so that's why I'm asking her..
Be kind to a NOOB please....
2012 F250 FX4 Lariet..CC Short box.
2012 Mustang BOSS 302 Laguna Seca
2003 Powerstroke Crew cab Short bed (The Tow Pig!)JLP CAI, MBRP 4 in exhaust.(Retired)
1993 Mustang LX Notch..The race car.Low 8's@170+ in the 1/4!(sold)
ulev1st is offline
post #2 of 8 Old 03-23-2012, 04:41 AM
MDarrough's Avatar
I think only the dually trucks come pre-wired but I may be wrong. I did this exact same thing on my '01 and my '08 SRW trucks, but I just tapped in to the tailight wires.
Here's a few available on ebay.
Light Bar
BTW - it's not a stupid question.
Mark
2011 F-350 4X4 Dually Lariat pulling a 2010 Sierra 355QBQ 5er -- Pic of Both
--- Sold - '01 F350, 8" lift, 38s --- Sold - '08 F-350 Leveled on 35s
MDarrough is offline
post #3 of 8 Old 03-23-2012, 04:57 AM
I agree with what Mark said, you could tie into a running light wire on the rear of the truck pretty easy. Also, the trailer wires are right there too and you could connect to the running light circuit there.
I'm kinda thinking all the Super Duty harness will have the wire you need. When the sun comes up I'll try to get out to my F450 and see if I can tell what color wire you need and where it is at. I remember seeing some "extra" plugs at the rear of my F250 when I put the air bags on and I bet one of them was for a triple light fixture.
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #4 of 8 Old 03-23-2012, 07:37 AM
travisH3's Avatar
Feedback Score: 13 reviews
i plan on just tieing into running lights on my 2010. I like the led light bars with turn signals but i went through 2 on my 2005 and led's kept going out so im just gonna get led running lights and mount them under the tailgate
T-rav
2010 F350 6.4- H&S Single turbo kit, 5" flo pro,No limit SS cold side kit, No Limit intake, MPD billet CCV/oil filler, newton leveling kit, RED Newton traction bars, custom projector retrofit in oem lights and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 8 Old 03-23-2012, 09:10 AM
OK, I got a chance to take a quick look under my truck.
I think you are going to be in luck for a couple reasons. The triple light bar on my F450 looks like something Ford bought at the local auto discount house and bolted onto the rear of the truck. You should be able to do the same. The wires it uses look like they are part of the factory harness and prolly on all Super Duty trucks.
When I speak a direction, , , , I will mean it just as you are sitting in the seat looking forward out the windshield.
RIGHT and Pass is right side
LEFT and Dvr is left side
UP is towards the sky
DOWN is towards the ground
FRONT or forward is where the headlights are
REAR or back is where the taillights are
That may seem elementary to most of us but I see people getting confused all the time. Since you are going to most likely be laying on your back looking up while doing this, it could seem reversed to you.
Under the rear of your truck you will find a harness attached to the bottom of the bed floor about 4 or 6 inches forward of the rear edge of the bed.. It comes from the left side and if you have a back-up camera from the factory, it will got to it thru a plug just a little right of center. If you don't have a camera, the wire plug will be covered with an orange rubber cover. This is the harness you need.
About 6 or 8 inches from the end of this plug, almost dead center of the bed, there is a two wire "pigtail" about 3 or 4 inches long coming out the side of the camera wire. This is the wire Ford plugs into the triple light bar. It has a small black plastic plug and the wires are colored black with yellow tracer and a yellow wire that prolly has a tracer but I could not see one without a mirror and light. I bet if you test this pigtail with a volt meter or test light you will find the yellow is positive when running lights are on and the black with tracer is ground.
If you find this plug, you could buy the Ford triple light bar and install it in 5 minutes. It just plugs in and there are twp screws holding it to the truck. I would recommend this as it does not cut into the factory harness and cause warranty troubles.
I know that was a lot of typing but when you look under your truck it will seem very simple then.
GOOD LUCK!!!
BedRug liner
mowdoc is offline
post #6 of 8 Old 03-23-2012, 09:23 AM
GOOD LUCK!!!
Talk about breaking it down Sesame Street, awesome right up!!
Thanks
←snow∞motion→ is offline
post #7 of 8 Old 03-23-2012, 09:37 AM Thread Starter
ulev1st's Avatar
Man THANKS everybody..MOWDOC...you are Da MAN!!!!
ulev1st is offline
post #8 of 8 Old 03-23-2012, 01:38 PM
atwoojr's Avatar
I know this is the 6.7 thread but just like he described, it is the same for the 6.4s. While changing out my bumper, I found the little harness hookup and it was labeled "CTR LIGHT", and this is on my F250....Ford makes it pretty dang easy when it comes to parts being interchangeable...Nice right up by the way
*2009 F-250 CCSB Fx4 *Ranch Hand Front and Rear Replacement *Blue LED's shining on front and back floorboards
*Zebco 33 Mod
*H&S Black Maxx *Diamond Eye 4" *aFe and custom airbox *Color matched side vents *Home-made Coolant Filter *Fumoto oil valve
[IMG][/IMG]
atwoojr is offline
