2011 engine block heater install - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-31-2012, 01:37 PM Thread Starter
There has been much discussion about whether a 2011 or later Ford 6.7 diesel has an engine block heater installed at the factory. I can tell you that in my case it was not so, I decided to install a block heater on my 2011 F250, diesel. I decided I wanted the Ford factory products and found them on the internet from a dealer in Missouri. I paid about $135 for a Ford heater element and electrical cord, including shipping. I thought I would share some information and pictures about my experience in installing a block heater.
Overall, the job is fairly easy. Installing the heater element is simple but the cord takes more work if you try to duplicate the factory installation. I recommend removing the right front wheel and the wheel well liner. This makes the job so much easier. Also, just to be safe, cover the battery connection to the starter solenoid with something non-conductive. Do this after removing the wheel well liner; easy. I used duct tape; the handymanís secret weapon. Below is a picture of the heater element installed after removing the factory hole plug. The installed heater is in the center of the picture. This will give you an idea of where it is located while looking through the wheel well. Generally, it is located above the starter solenoid, just in front of the transmission on the engine block (of course).
You have to remove the factory hole plug before installing the heater. It is the plug that has a 9/16 hex socket. You will need a 9/16 hex bit that can be driven with a wrench. It might be possible to use an Allen wrench but the plug is installed fairly tight. I had to use a long handle wrench. The plug is threaded and just backs out. I crawled under the truck to loosen the plug and this made the job a little easier. The plug and the hex bit are shown below.
The heater element from Ford needs a 1-1/4 inch socket to install it. Have your heater element ready to install as you remove the plug and you will lose very little coolant. I lost only 4 ounces making the swap. You may be able to avoid buying more coolant but I bought more just in case. Cost: $23 a gallon; outrageous but it helps maintain warranty status of the truck. I suggest you put thread anti-seize on the threads of the heater element before putting in. Just a suggestion.
As I said before, I chose the Ford element and harness. Here is a picture of the harness, if you want to know what it looks like. I like the fact that Ford insulated the harness and added fasteners that plug into factory holes in the frame for a secure installation.
I completed the installation in 2 hours but I spent most of the time installing the electrical harness. Your installation does not have to take this long. Below is a picture of the cord plugged in to the heating element.
I have only used the block heater a couple of mornings as of this writing but so far it is doing its job. Good luck.
hamradioactive is offline
post #2 of 10 Old 01-31-2012, 04:28 PM
camdenlake's Avatar
Quoted: 15 Post(s)
Think it might be a geographical thing. My truck and all the 2011+ i looked at here in canada all had the factory blockheater.
Josh
1999 F150 4x4 With the not so stock V10
2009 Shelby GT500 - Grabber Orange
2012 F350 6.7 CC SB FX4 - Sold
2015 Explorer Sport - Black on Black - Sold
camdenlake is offline
post #3 of 10 Old 01-31-2012, 07:19 PM
LFD132's Avatar
Quoted: 3 Post(s)
Josh
I don't think there is any rhyme or reason to which trucks get block heater or where the trucks go. I bought my truck new in central Florida and it came with a factory block heater.....really.....what is the chances I will ever use that thing. On the flip side I have heard of guys buy a new truck in s Dakota and it didn't have a block heater. Crazy
Sent from my DROID RAZR using Tapatalk
[SIGPIC][SIGPIC]2013 F250 FX4
LFD132 is offline
post #4 of 10 Old 02-01-2012, 02:53 AM
Hawkeye Diesel's Avatar
I bought mine in Iowa, one of the states that Fords website says all trucks will include a block heater, and when I crawled under the truck, no block heater.
Good write up man! I might have to run up to the parts department where I bought my truck and pick one of these up
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #5 of 10 Old 02-10-2012, 02:43 PM
Dr.Evil's Avatar
Just picked up the parts to do this tomorrow. Thanks for the write-up! Looks pretty straight forward. It doesn't get super cold here in Reno, but it will be nice for it to warm up faster in the mornings.
2011 F-250 Lariat Ex LB 6.7
2001 F-250 R.C. LB 7.3
Dr.Evil is offline
post #6 of 10 Old 02-10-2012, 02:46 PM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 3 Post(s)
Originally Posted by LFD132 View Post
I don't think there is any rhyme or reason to which trucks get block heater or where the trucks go........
Agreed, just another way to make a lil more money........hell the dealership wanted to charge my buddy $500 for the harness and install on his rig
-Julian
Facebook
4th 6.fo
TwinTurboStroker is offline
post #7 of 10 Old 02-10-2012, 04:32 PM
only reason i installed the cord on my 06, and reason i ordered one on my 12... it doesnt get cold often here in Florida, and 30* on average when it is... but sure is nice to hop into the truck with an engine that is somewhat warm, plus who knows where I might go in the future.
also opted for the supplemental heater and heated seats as well... lol so block heater might not be all that important anymore
2006 F350 XL CC LB 4x4- 71k miles Stolen 12/5/11
Replacement
2012 F350 Lariat CC LB FX4
Crashking is offline
post #8 of 10 Old 12-13-2013, 12:34 PM
Where is the block heater cord located if mine does have it?
bjackson is offline
post #9 of 10 Old 12-13-2013, 02:16 PM
IBEW Journeyman Lineman
PolarBear's Avatar
My '12 came with it and it was ready to go in the main open area in the front bumper just to the passenger side of the license plate bracket.
2012 F350 XLT CCLB 4x4 6.7
PolarBear is offline
post #10 of 10 Old 12-13-2013, 05:22 PM
I_AM_RP3's Avatar
Nice write up, and thanks, mine should be here Tuesday, getting down in the low teens here at night, can't wait to get it installed and see what kinda difference it makes. I bought a timer for it, how long before I am ready to leave she I have the block heater turn on? 2 maybe 3 hours?
I_AM_RP3 is offline
