Tire pressure 2011 F-350 KR - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 16 Old 08-06-2011, 05:35 PM Thread Starter
I just picked up my new pickup yesterday from the dealer. It has the 20 " rims on it and when I looked at the tire pressure sticker on the door jam it says to run 80psi rear and 60psi front. I like the truck but it does seem to ride ruff in the rear. I was thinking about airing the rear tires down to 55-60psi when not hauling or towing. What is everyone else running for psi and does it make a big difference on ride?
Carbondeath is offline
post #2 of 16 Old 08-06-2011, 05:48 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 14 Post(s)
It will make a difference but if you air them down, you TPMS will probably trip the light and you'll get a warning showing on your dash.
dhanna6powerstroke is offline
post #3 of 16 Old 08-06-2011, 08:54 PM
ups 6.0's Avatar
I'v had them down to 65 psi in the rear but it seems to bounce more,now i'm running 80 psi and switch to Bilsteins shocks.....wayyyyy better
2011 F350 Lariat,6.7,3.55, crew cab, FX4, longbed w/custom Reese 5th wheel hitch,white,black leather,moon roof,navigation.
ups 6.0 is offline
post #4 of 16 Old 08-06-2011, 09:02 PM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
Yeh I noticed that with my new tires. Bouncy ride at 70psi actually caused some odd wear at first. Then at 80psi tires rode like butter.
2002 f250 BFT Edition
dereku is offline
post #5 of 16 Old 08-07-2011, 03:59 AM
psdcasper's Avatar
I have the same setup up as you, 80 in the rear it rode like a board. I dropped the rear tires down to 50 and it now rides very well for a 1 ton truck. TPMS is now on but to me it's worth the ride dirrerence. I feel Ford should have the sensor set up that if any one of the tires goes below 50psi or so it should then turn on the light. For me and the way I use my truck 60-65 in the front and 50-55psi in the rear works very well and always did in all my super dutys. I would only air up the rear tires if I was going on a long trip and hauling heavy. Hope this helps..
2015 F-350 CCLB Loaded, Lariat Ultimate, FX4 Off Road Pkg, Reese 5th/Goose Hitch, Fully Loaded.
2014 VW Passat TDI (DIRTY DIESEL )42mpg on the highway (Wife's Ride).
2011 F-350 CCSB 6.7L, Loaded, Lariat Ultimate, FX4 Off Road Pkg, Reese 5th/Goose Hitch, White on Black. (43K as of 4/14) H&S Mini Maxx, Flo Pro delete pipe, Magna Flow Muffler and Sinister EGR Delete . Sold 2/15
psdcasper is offline
post #6 of 16 Old 08-07-2011, 07:56 PM Thread Starter
Yeah thanks for the replies. Psdcasper I think I will do the same as u and try running my rear tires at 50-50psi. I did this on my last truck an 08 duramax and it seemed to work good and did not affect tire wear. Having the light on the dash is not that big a deal for a better ride my suspension might be a bit stiffer right now to because everything is brand new.
post #7 of 16 Old 08-09-2011, 11:47 AM
doczenith1's Avatar
80psi is DEFINITELY too much air in the rear tires when unloaded. In the past some dealer's would lower the TPMS values for you but from what I've heard Ford has updated the IDS software to not allow this anymore.
My solution was to re-train the tire locations (page 236 of the owner's manual) and tell the computer that the fronts are in the back and the backs in the front. This way I can run the rear tires as low as 49psi (65 x 75%) and run the fronts as low as 60psi (80 x 75%) and not have the TPMS light come on.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
Link: Fuel Mileage Spreadsheet With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
Link: Rapid-Heat Sup Cab Heater Test Data and Graphs
doczenith1 is offline
post #8 of 16 Old 08-10-2011, 06:57 AM
psdcasper's Avatar
Thanks for the heads up. I am going to try it this weekend. I didn't realize that the system was looking for only 75% of recommend air pressure. That should fix me right up.
post #9 of 16 Old 08-10-2011, 10:12 AM
Rudy's diesel performance's Avatar
You can also adjust or remove the TPMS light with the H&S tuners.
Sales @ Rudy's Diesel Performance
*CONTACT US FOR SPECIAL PACKAGE DEALS ON SPARTAN, SCT AND H&S PERFORMANCE DPF/CAT DELETE KITS*
(919) 383-9300 OR Toll-Free # 1-866-757-6537
Rudy's diesel performance is offline
post #10 of 16 Old 08-15-2011, 05:26 PM
psdcasper's Avatar
Hey just to let you all know it worked for me. I set the Front tires at 68psi and the rear tires at 55psi and trained the tires starting with the left rear and working all the way around to the left front. 200 miles and still no light. Thanks for the info, worked great!
