| General 6.7 Discussion General 6.7 Discussion |
Brakes - Need some Improvement?
Had the truck for about 10 days now, put about 2,400 miles on it already. My only real complaint is the brakes, the 1 or 2 times where I have had to put my foot into it really hard I wasn't totally sure that I was going to stop in time. Neither time did I have a trailer in tow, or any load in the truck.
Truck is still bone stock. Didn't know if anyone else felt like the brakes on these trucks are a little under sized. |
I think my truck stops better with a trailer than without. I am very impressed with the trailer brake control - but if your trailer brakes ever fail you are right - the truck's brakes do not match the rest of the its capability. (both wheel brakes and exhaust brake need improving)
Sadly I haven't had a "real" load behind the truck yet to even see. But your point about trailer brakes is a good one - I know some of my trailers need more frequent inspections (not by the DOT though).
This don't sound good specially with your F350 having the Better Brakes :~(
They are doing away with them on the 2012's... maybe they aren't as great as everybody thinks ? |
I tow about 20% of my driving time. So majority of the time it's just the truck. I think the brakes are great. I don't know what you're comparing them too. I've had maybe 4 emergency stops in the 25,000 miles I've got on mine and each time it's more than surpassed my expectations for slowing down an 8500lb truck.
Seeing as you've only had the truck 10 days and you've already "had your foot in it" twice. May I suggest just slowing down. The brakes are not undersized. They fill up an 18" wheel almost completely. The only thing they could make bigger is the caliper. Have you looked at your's yet? They told me that the brakes need about 500-1000 miles to "seat" together. Which makes sense, so I'd just give it a little bit. |
mor4wd - I am sure I am little heavy with the go pedal, sometimes I'm even checking out the hot blonde in the low cut top in the lane next to me rather then looking ahead at the traffic that has stopped. It’s a trade off.
End of the day I am comparing this to my old 2006 F-250 CCLB, running 315/70/17 BFG A/T on stock wheels and brakes. All in all, I am very happy with the truck, and I am sure I will get used to the service brakes taking a little longer to stop then expected. |
I was doing a little research on CGI (compacted graphite iron). It seems one of it's first uses was for the braking system on high speed rail trains in Europe. These trains run 175+ and they found the rotors for the breaks weren't holding up to the heat. They tried CGI and it worked. So I wonder why nobody is making CGI rotors for these trucks?
Odd. Your brakes should be fabulous. Are you sure everything is working correctly?
