WHAT IS DIFFERENCE IN RPM AT 75 MPH BETWEEN 3:31 AND 3:55 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-22-2011, 09:50 AM Thread Starter
Hello. I am going to order a 350 cc long box shortly and am just trying to figure out which rear end I want. Tow pretty much daily but nothing above 6000 lb on a normal basis. Curious on how much the difference is on rpm and or mpg between these two different gears when empty as either one will work fine for what I tow. Usually run about 75 on highway when I'm not towing. Just for comparison lets figure stock 18" wheels. Thanks for any input.
brightideaselectric is offline
post #2 of 3 Old 05-23-2011, 06:31 AM
Based upon a gear chart that I saw for the 6.7's, if you order a 3.31 with 18" wheels and then put on 20" wheels the difference is about 100 rpm across the board.
BlueF350 is offline
post #3 of 3 Old 05-24-2011, 07:06 PM
4x4ord's Avatar
Quoted: 3 Post(s)
If the tires are the same size on both trucks the rpm of the 3.31 will be 93% the rpm of the 3.55. With 275/65r20" wheels that works out to 1760 rpm on the 3.55 and 1637 on the 3.31 at 75 mph. With 275/70 r 18 " tires it works out to 1808 rpm with the 3.55 and 1682 with the 3.31.
4x4ord is offline
