High Oil Temp?? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 29 Old 05-14-2011, 08:33 AM Thread Starter
mor4wd's Avatar
High Oil Temp??
I'm just curious. When should I be alarmed at the oil temp. Couple weekends ago pulling 18k on I-15 through Nevada it got pretty hot. Tranny dropped to 4th doing 70mph pulling a grade and I was just watching the oil temp go up, and up, and up. Hit 242 degrees right as I crested the top. All the other gauges were fine. Just wondering if anybody has seen these kinds of temps or not.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #2 of 29 Old 05-14-2011, 10:50 AM
WHOA! thats hot...
Dietoremain is offline
post #3 of 29 Old 05-14-2011, 10:53 AM
late_99_PSD's Avatar
Hmmm, thats odd. Might wanna get that figured out.
Allen
1999.5 F-350 7.3, six-speeed
If Canada was that great, it would be a state...
When seconds count, the police are just minutes away.
"Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin
late_99_PSD is offline
post #4 of 29 Old 05-14-2011, 10:57 AM
Quoted: 2 Post(s)
wow thats hot. What were the coolant temps reading? Killer truck by the way!
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 29 Old 05-14-2011, 11:30 AM Thread Starter
mor4wd's Avatar
You can see the coolant temp right above it in the picture, along with the trans temp. For some reason Ford decided not to have the ability to see actual coolant temp alongside oil temp. But the gauge was reading normal. So you guys think I should bring it in? It immediately dropped back to 205 when I got over the top. I don't know if I should worry or not.
mor4wd is offline
post #6 of 29 Old 05-14-2011, 11:39 AM
If it dosen't do it again then I wouldn't worry about it, but I wouldn't make a habbit of it.
Allen
post #7 of 29 Old 05-14-2011, 11:46 AM
What oil weight are you running.....I pull a small trailer ....I run 5W-40 Rotella T6 syn oil.
There was one time that my oil temp got to 215.....every so often pulling the trailer I will check the oil temp....keep us informed....
Smoke2008 is offline
post #8 of 29 Old 05-14-2011, 11:56 AM Thread Starter
mor4wd's Avatar
Running Rotella 15W-40. This was by no means a "small" trailer, it also wasn't at it maximum GCWR. I'll let you all know what the dealer tells me.
mor4wd is offline
post #9 of 29 Old 05-14-2011, 12:57 PM
Quoted: 2 Post(s)
thats just a dummy coolant gauge too though, it might not even move till its tooo late
2000 DRW CC 7.3
post #10 of 29 Old 05-15-2011, 06:42 AM
We saw 223 when pulling our 13,000lb fifth wheel up a long 6% grade in PA but not that high.
silverback31b2 is offline
