| General 6.7 Discussion General 6.7 Discussion |
What's the scoop on the locker. Should I get it or not? Whoops, too late. I already did.
Anyway I plan on highway driving and a lot of towing. From what you guys know about it so far what is the best way to use it? Advantages and disadvantages. |
I definitely like it and have used it many times off-road. I think it disengages above 30mph. (That speed may be incorrect but I haven't read up on it in a while.)
Awesome..use it in low traction when 4x4 is not really desired...it wil LOCK the rear wheels as a welded posi trac, meaning if you lock it, take a corner on asphalt one tire will bind, leaving marks on the asphalt...great tool. Disengages at 40-45 mpg I think...(automatically, then re engages again when you slow back down. I take traction control off when I use it)
I Think it's closer to 30-35 on the Disengage ?
I have the Ford book at work in My locker,I will find Out tonight if i can Remember LOL |
Straight from the manual.
The electronic locking differential (ELD) is a device housed in the rear axle which allows both rear wheels to turn at the same speed. It provides added traction on slippery and/or off road surfaces, particularly when one wheel is on a poor traction surface. The ELD may be locked or unlocked by the vehicle operator and can be engaged or disengaged on the fly. When the axle is unlocked it will function like a standard rear axle. When the axle is locked it will not allow the rear wheels to rotate at different speeds when turning. It is not recommended for use on good traction surfaces such as dry pavement. Doing so may result in abnormal driving behavior and noise while cornering and excessive tire wear. The ELD is affected by the following conditions of your vehicle: • On 2WD vehicles and 4WD vehicles in 2H (4X2) or 4H (4X4 High), the ELD will not engage if the vehicle speed is above 25 mph (40 km/h). • On 2WD vehicles and 4WD vehicles in 2H (4X2) or 4H (4X4 High), the ELD will automatically disengage at speeds above 25 mph (40 km/h) and will automatically reengage at speeds below 19 mph (30 km/h). • On 4WD vehicles in 4L (4X4 Low), the ELD can be engaged at any speed and will not automatically disengage |
Thanks for the info,
Sounds like it should be useful. Going to get the truck now. |
