Electric Exhaust Cut Out - Ford Powerstroke Diesel Forum
Old 05-05-2011, 10:10 AM
Any one know if I will pass inspection/ keep warrenty if I were to place an electric cut out before my dpf and cat?
Old 05-05-2011, 03:12 PM
I believe any kind of modification to the exhuast system will void the warranty.....but I could be wrong!! Anyone?
Old 05-05-2011, 03:26 PM
most likely
Old 05-05-2011, 06:06 PM
How is that going to work???
Old 05-10-2011, 09:45 PM
You could make the argument that when your off the road and on private property that you do not have to meet emission standards. That would be my defense.
Old 05-14-2011, 06:58 AM
You could argue that to the inspectors...Ford will probably just give you a tight little smile and void the warranty on related parts and systems.
Old 05-14-2011, 07:10 AM
Its just not going to work properly unless you disable and enable the emissions systems.
The exhaust system sensors will cause a light to come on. You cannot pass inspection with a light on. You might not even be able to drive the truck.
You can't have a convertable vehicle. Its either registered for use on the road or its not.
They will not warranty related problems. They might even fight with you about seamingly unrelated problems.
That being said almost anythings possible. I have seen inspection stations just give out stickers for a list of vehicles without even taking them in.
Old 07-28-2011, 04:58 AM
Thumbs up My two Cents.
By doing the cutout before the DPF...It would just be a matter of having a tuner, to go from (Ford) Stock Tune to your Tuner...Like Spartan or H&S Tuner (or what ever you have) that has a DPF delete tune...and the switching the cutout to push the exhaust to the DPF, stock tune, to straight exhaust, Non-DPF Tuner. A.K.A. Off Road Tune which you would only use at the track and not anywhere on the street, because every 2008 and newer diesel truck out there has a DPF on it, I mean who would do such a thing and take the DPF off??
It can be set up as a dual exhaust, just one side would be the tree hugger side and the other would be the non-tree hugger side...yeah it may look odd, but it is a solution. Or dump both pipes out next to each other, side by side at the back of the truck close to where the stock exhaust comes out The hard part of this is to build a custom exhaust to the rear from the cutout, so you don't soot up the underside of your truck.
As far as the warranty...according to my Dealership, it's a mod to the exhaust thus voiding the warranty. SO...after the warranty is over then the issue is to have it pass state inspection. That would be my question. Waiting for the warranty to run out is like a kid waiting for Christmas. My argument would be it is in place for off road/farm use/track use. (Wow, I feel like a politician saying that last statment) or... find a non dealership.. A.K.A. a local garage and see if you get someone to pass it if it is illegal. Maybe a Street Rod enthusiast could chime in on the legallity of that. Or you could tell the cop that "Loud pipes save lives." I'm only chiming in because as soon as my warranty is OVER...the cutout is getting put on, with an electric control. Not worried about the extra weight of the DPF on the truck...having a tuner moves 8000lbs of steel on 4 tires down the street nicely.
Old 07-28-2011, 11:14 AM
how about the exhaust switch being on top of the engine, like the cam inverted old flathead v-8's with the exhaust out the hood!!! Have a 'snap fit' straight exhaust thru the hood, when not in use, pop it out, a fiberglass 'pop in' hood scoop. I saw it on Scooby Doo so I KNOW it will work!!! (ruh row!!!)
