0-60 with the 6.7 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-27-2011, 04:59 PM Thread Starter
4x4ord's Avatar
Quoted: 3 Post(s)
0-60 with the 6.7
I am curious how much variation there is amongst the 6.7's in acceleration. What is your 0-60 mph acceleration time. Traction control off, 4x4 engaged and state rear end ratio and tire size. Also curious how much difference the H&S makes.
4x4ord is offline
post #2 of 7 Old 03-28-2011, 05:40 AM
mor4wd's Avatar
Truck in signature. 3.55 rear end. Measured with my old DashDaq was 9.45. Also had two 300 pounds of man in it, and 400 lbs of cargo.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 7 Old 04-07-2011, 06:35 AM
doczenith1's Avatar
Quoted: 3 Post(s)
My launches weren't the greatest so I might be able to do a little better on the numbers. Using the Speedview Android app I got the following numbers. I'm not sure how accurate the Speedview app is but I would think within +/- 1 second.
0-60 - 7 sec
1/4 mile - 14 sec
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
Link: Fuel Mileage Spreadsheet With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
Link: Rapid-Heat Sup Cab Heater Test Data and Graphs
doczenith1 is offline
post #4 of 7 Old 04-07-2011, 07:14 AM
0-60 - 7 sec
1/4 mile - 14 sec
I don't see that you have a tuner so your numbers are way off, but I hope that im wrong I think a stock truck run mid 16s in the 1/4
2011 F250 6.7 Lariat Ultimate FX4 CC Tuxedo Black Tan Bottom
stroke11 is offline
post #5 of 7 Old 04-07-2011, 09:37 AM
doczenith1's Avatar
Quoted: 3 Post(s)
Yeah, I definitely need to grab a friend and a stopwatch and see what the actual numbers are. The neat thing about the app is that it automatically starts timing you when you start moving and then stops when it senses either 60mph or 1/4 mile. Makes it easy to grab some times while solo. Although, if they're off by 2 seconds the numbers are pretty much useless.
Al Bedford, P.E.
post #6 of 7 Old 04-07-2011, 11:46 AM
The problem with gps is that most devices (especially cell phones) don't update often enough to get an accurate reading.
Not saying I won't try it if the app is free.
2011 F-350, 5% on sides back and eyebrow-35% on windsheild, B&W hitch, Weather Tech mats, Tailgate Assist, Hornblaster Conductor Special 240, Toyo M/T 35", Incubus Krawler 20x9, 2.5" ready lift stage 3.
cdrracing is offline
post #7 of 7 Old 04-08-2011, 07:40 AM
mor4wd's Avatar
Let's see some more numbers. So far we've got two including my own and it looks like mine is a dog. I don't think it is though, I know my numbers are dead on, the Dashdaq reads the speedometer through the OBD port. I could've done a better launch but it's so hard to feel out that stupid torque management.
mor4wd is offline
