| General 6.7 Discussion General 6.7 Discussion |
Check Coolant Additive??
WTH is this? Come up twice on my screen. Dealer says it's nothing to worry about??
It is an electronic timer by both miles and days. Do not ignore it - check coolant for the need to refresh, then reset. This is not a minus 65 versus minus 30 degree mixture check but rather ph due to contamination.
it is something that the dealer needs to look at. they will test your coolant. its a notification that it needs done.
Is this the same additive the 7.3 needed? I remember having to add to an additive and check the pH every so often.
no it's not the same VC-8 as the 7.3/6.0 require and the coolant doesn't use the same test strips either. 6.7 takes a specialty orange coolant revitalizer VC-12
Thanks for answering my question.
I went to the dealership today to order the 3-way HD Coolant Test Kit ST3106-A since nobody stocks this crap!
Also, the additive you need is the Motorcraft Specialty Orange Engine Coolant Spec #WSS-M97B44-D (Motorcraft Spec Number). In addition, I have attached the detailed instructions on how to test and what to test for along with what the results mean. I hope this helps everyone it sure helps me! |
At what mileage are you guys getting this message??
![]() What does the dealer charge for this check? |
If you reference the previous posts I believe the computer defaults at a certain number of miles or engine hours. My truck started doing if at 12,000 miles. Also, it does not mean that the coolant needs additive only checked.
I am not sure what the dealer charges. The dealership I went did not have anything and told me it would be April before Motorcraft could send them the coolant additive. I just ordered the test strips (bottle of 70 for $40.00) which is the smallest I could get. As for the coolant additive I can't find it anywhere. If anyone can track it down let me know. |
