DEF, Newbie question - Ford Powerstroke Diesel Forum
Old 02-09-2011, 03:10 PM
Ok, I have read the urea stuff will freeze at about 10 degrees....
What happens when the stuff does freeze? I understand that ford has a heater or something in the tank (only works when motor is on right?), but isn't the tank prone to bursting because of the stuff freezing I ask because the temp was -12 when I got up to go to work this morning. The other week made it to -24!
Old 02-10-2011, 06:38 AM
I'm sure they've thought this through, but subscribed for info.
Old 02-10-2011, 11:00 AM
Yes, the DEF is heated. Your truck will not attempt to use any until it is thawed and ready. The DEF is stored in a bladder, rather than a solid tank, to prevent freeze damage.
Also, I believe this bladder is located above or just along side the fuel tank in a boxed thingy that is somewhat flexible. I tried to trace the fill line once and that is where I thought it went but did not want to lay down and get dirty that day.
Don't worry about the DEF in cold weather, it takes care of itself.
Old 02-10-2011, 07:21 PM
Thanks for the info, I was fairly certain the def was nothing to worry about since there are a ton of these trucks running around this area. Just trying to get all my info straight before deciding to pony up the cash for a new truck!
Old 02-11-2011, 07:01 AM
I've been out in -11 and the wind chill was -25 with no problem.
