Anybody seen the Carli suspension system on a 2011? - Ford Powerstroke Diesel Forum
Old 02-08-2011, 09:32 AM
I'm looking for a lift for my new 2011 King Ranch and I'm interested in the Carli 2.0 Performance setup with the new Bilstien 7100 series resevoir shocks. This is a 4.5" lift. Does anybody have/seen a 2011 F250 with the Carli system on it? Anybody rode in one? These lifts cost a little more, but the ride quality is supposed to be amazing and it's designed to actually be used off-road as well so it's not all just for looks like the Procomp stuff and a few others.
Any opinions?
Old 02-08-2011, 09:50 AM
Let's Run'em
I haven't seen one yet nor have a I heard of them having a system out for it yet. I have nothing but great things about Carli suspension systems, I was gonna run the pin top 2.5 on my 2010 F250, but I decided to it was better to wreck the truck instead
Old 02-08-2011, 11:02 AM
They have several different systems out for the 2011. They have a Starter setup that is the base package, the 2.0 Performance setup that is a step up, and the 2.5 Performance which is a complete coil over system using King Coil Overs. The coil over system is nice because it's a bolt on system that does not require you to cut/modify the spring buckets on the truck so you could return it to stock if you wanted to. The Coil Over system King has for the 2011's requires you to cut the spring buckets so it's a permanent thing.
Carli has all the systems that I listed on their website as well as a 2011 F250 that they installed the system on already and put it to the test with a set of 37" Grabbers.
