| General 6.7 Discussion General 6.7 Discussion |
Stock boost levels?
Simple question.. What does your 2011 6.7L boost at?? Stock, no tuning.
The highest I've seen is a touch over 20psi.
Does your hold 20 steady? Or does it fall to 17-18 psi by redline?
I don't know. I've just glanced at the gauge while under load and that's the highest I've seen. Next time I'm out driving I'll see what it does as I approach redline.
Mine will hold steady at about 20 under WOT.
My gauge indicates 21 psi and stays pretty close at red line. The harder I pull on it, the better it holds max boost.
When I put my foot into, I get 20 psi. I haven't held the pedal down to long, so I can't tell you sustained.
What are you guys doing for gauges?
