| General 6.7 Discussion General 6.7 Discussion |
Pass Thru/Upfitter/Off Road Light Install
Hey guys I just got through installing my off road light set-up and thought I'd share it with you. Instead of re-posting the entire thing, I hope it will be OK to share the link with you! If your like me you are a member a more than one forum and nothing against this one, I just don't feel like posting the whole thing twice! Hope you like and I hope it helps!
Pass Thru/Upfitter/Off Road light install (PICS) - Diesel Forum - TheDieselStop.com |
...none of those repetitive full size pictures or quoted messages either...sweet...
That's what I was aiming for! Hope it helps!
Hot off the press!
Beautiful doesn't even describe the pure awesomeness in those pics.
Great setup and tutorial! Wouldn't it be almost the same for any other lighting application such as a light bar on the roof or dashmount? |
Thanks Jimmy! The setup should be the same, as long as the wiring kit is the same. The KC kit comes with everything you need, including relays and switches. I just used the upfitter Vs the stock KC switch and connected the GREEN lead to the pass-thru wire. Here's the schematic.
Thank you for the photos.. Your truck looks great with that set-up
What diameter size is the lights ?
Sent from my iPhone. |
