Alternator Preference? Dual vs. Heavy Duty - Ford Powerstroke Diesel Forum
Old 01-05-2011, 08:51 AM
Question Alternator Preference? Dual vs. Heavy Duty
Anyone have a preference on running Dual alternators vs. the HD alternator? Assuming Duals provides a level of redundancy but just checking.
Thanks
Old 01-05-2011, 06:04 PM
No opinions? Not likely...
Old 01-05-2011, 06:05 PM
i would go with a single big unit... like this bad boy: '99-'07 Ford F250/350/450 & Excursion Powerstroke TAD 270 Amp SP series alternator
Old 01-05-2011, 06:32 PM
Send a message via AIM to ididntdoit5150 Send a message via Yahoo to ididntdoit5150
ive been wondering this same thing...
Old 01-05-2011, 06:54 PM
For the rapid heat heater, it is required...my opinion? uhm, if you want a rapid heat heater...? Might want to lean towards accepting having two alternators...
Old 01-06-2011, 11:02 AM
I think this is going to be one of those personal preference deals. From what I've been told, it is slightly more efficient to run one larger unit than two smaller. However, the tradeoff is the benefit of always having a backup.
Old 01-06-2011, 06:20 PM
If you were pulling a trailer with a ton of running lights, triple axle electric brakes, and running power inverters off every cigarette lighter outlet than you may need the doubles.
Old 01-06-2011, 06:28 PM
I prefer dual alt's.... That's what I have on mine
Old 01-07-2011, 04:09 AM
The duals were intended for ambulance use. Unless you have someone who is depending on life support equipment to stay alive in your truck bed, the duals are totally unnecessary, inefficient overkill and complication..
If you can't get by with 130 amps, especially when most trailers now use LED lighting, something's wrong.
Old 01-07-2011, 02:14 PM
Dual alternators - to be able to run a 3KW inverter.
