Centane Booster or not? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-23-2010, 09:27 AM Thread Starter
Mason73's Avatar
Ok so this is my first diesel (6.7) and it has 1600 miles on it now, should I be using this Cetane Booster or not. Are any of you using it and how much?
Mason73 is offline
post #2 of 4 Old 12-23-2010, 10:26 AM
ebusa's Avatar
YES! I used the Ford Centane Booster and Performance Improver. Engine runs smoother and I notice more power. I use about 4-6 oz per tank. '
Give it a try!
-Evan
Semper Fi
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, 06 Chrome Package
5'' Tuff Country Lift
Toyo MT's 35's with Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tuned by TSD & IDP
Stock Airbox, NON-MAF Truck
GT3788VA POWERMAX Turbo
DiProcol Optix EGT & Boost Guages , Scangauge II
ebusa is offline
post #3 of 4 Old 12-23-2010, 11:05 AM
mc5150's Avatar
I used it in my 6.4L and now in my 6.7L. Seem to get 1-2 additional mpg.
I use the Diesel Power Service Cetane Booster.
2011 F350 Lariat CC SB 6.7L
Previous: 2008 F350 King Ranch CC SB 6.4L
mc5150 is offline
post #4 of 4 Old 12-24-2010, 06:02 AM Thread Starter
Mason73's Avatar
So I did a little research on this Cetane issue and here in California I guess it’s a good idea. Ford recommends about 45 Cetane for the diesel you use in the 6.7, however the diesel we get out of the pump here is around 40 (Chevron), if I understand it correctly 6 oz. of the Booster in a full tank of fuel should bring you up 4-5 points in your Cetane level? Does this sound right?
Mason73 is offline
