2008 6.4 Starting Problem - Ford Powerstroke Diesel Forum
Old 07-12-2010, 03:00 PM
Has anyone heard of this problem?
My 2008 6.4 has little over 15K miles, this has happened about 3 times now.
We stop for a few minutes, maybe 30 minutes to 1 hour, come back to the truck and it cranks, starts and dies. Then when you try and start again it just won't crank. I found that if I disconnect both batteries and then reconnect them it will crank but not start, if I turn the key off and on it will then crank a start just fine. I has done this three times over the last 3 or 4 months. I took it to the dealer the first time but of course there were no codes or no problem found. One time it was in my garage when it wouldn't crank so I was going to have it towed in the next day but, won't you know it it started just fine the next morning. Any Ideas???
Hoffer
Old 07-12-2010, 07:25 PM
wrong forum, try the 6.4 and you should get a response....
